Old 10-13-2004
MonkeyShock's Avatar
MonkeyShock MonkeyShock is offline
Half of 5150=?
MonkeyShock is a splendid one to beholdMonkeyShock is a splendid one to beholdMonkeyShock is a splendid one to beholdMonkeyShock is a splendid one to beholdMonkeyShock is a splendid one to beholdMonkeyShock is a splendid one to beholdMonkeyShock is a splendid one to behold
Again with the pre-amps.
I've been recording with an A/E Ovation. I'm going to pick up a Stratocaster this weekend. I want to record DI. I need some suggstions for a pre-amp or direct box for an electric. Can I use the phantom power and/ or mic pre on the (Aargh) Behringer mixer to get a decent sound for recording. I have to admit to not doing my homework on this one, but would appreciate any input.
I can't mike an amp as I have to keep the noise down for now.
Thanks mucho!
...no problems, only solutions.
Old 10-13-2004
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Yo Electrocuted Tree-climber:
Well, if you have a condensor mic, you will need phantom power to get a signal up to line level.
Most mic pres, outboard, come with phantom power. I have phantom power on my 2816 but don't use as I run the mic through a Grace Design.
I can record "silently" and so can you.
Add reverb when you are ready to mix. However, put reverb in your cans as it kind of makes you feel good all over hearing that nice vibrant sound. And, even if you over-do reverb in the cans, it isn't recorded on most units.
I'm not familiar with your gear but if you get a copy of Tape OP, which a free zine, they review Many mic pres at all price levels.
Do a little experimenting and see what you get and, then, ask some more.
Green Hornet
Old 10-13-2004
manning1 manning1 is offline
Banned
Location: Canada.PLEASE NOTE>>I DONT WORK FOR NOR HAVE I EVER WORKED FOR ANY COMPANY WHOSE PRODUCTS I LIKE AND RECOMMEND.
manning1 is on a distinguished road
hi ms - hows it going ?
you CAN record with a di box. plug the output of the strat into the di box.
then you need a 3 pin mic cable between the di box xlr output going to mic in of the mixer. (you dont use phantom power in this application).
bring up your mic gain ever so carefully.
but you know there might be a more interesting way. which gives you more variety. now you might not like the sounds of these.
but you could plug the strat into for example a digitech rp 50 or a v amp that you find used. then take the output of the unit into LINE IN of mixer for sending to the sound card. these type of devices attempt to emulate certain guitar amp sounds, and provide a variety of models of different guitar amps. some folks like the sounds - some dont.
Old 10-13-2004
Half of 5150=?
Thanks for the input emerald toned flying insect.
Hey Manning! How is it? My recordings have improved immensely. I've got a good handle on Magix, and my singer and I are waist deep in songs we're putting final touches on for our first 6 song cd. Good to see you around mate.
After posting, I nearly hit myself as I've been recording bass DI with excellent results for months, so nothing should change with guitar...I don't know what I was thinking, guess I wasn't. It's probably time to check out these Digitechs, as well as my old favorite-Ibanez tube screamer. Thanks again guys.
Cheers!
Old 10-14-2004
Banned
glad your getting there with music studio.
you figured out the fade out handles on fadeing out small clips ok ?
a trick i use is the pitch option in the track object editor.
take a lead guitar break, cut it out of the rest of the track, then create a harmony up or down. sometimes works, sometimes doesnt. for double electric leads.
all the best.
Old 10-14-2004
Ronan's Avatar
Ronan Ronan is offline
Force of Nature
Ronan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond repute
Actually everything changes with guitar. Recording bass direct with a good bass, DI and player can often lead to amazing results. Recording guitar direct leads to awful results most of the time. On a good day the results with be mediocre. Others opinion will vary.
Ronan Chris Murphy
Ronan's Recording Show My "TV Show" about recording.
Home Recording Bootcamp teaching other guys how to get in trouble
Old 10-14-2004
tollbooth's Avatar
tollbooth tollbooth is offline
Senior Member
tollbooth is on a distinguished road
gonna be dull but...
hey mr m shock!
if played with for long enough, i now swear by my PODv2 - it's by no means everyone's cup of tea - but it does the job for me. i tend not to leave it there mind you, i can't stop fiddling (comes to us all!) and it inevitably ends up being fed into my trusted TFPro preamp (P2) for a little compression and EQ before it gets to the motu a/d converters.
you sometimes have to work at the POD and i don't think i've ever used a preset for a track yet - first thing i do when it powers up is stick it in manual mode.
as the clean sounds are a little cruddy on the POD though, i even sometimes just shove a Boss Chorus, Compressor and Dig Delay pedal chain straight into the TFPro.
Before all this mind you, i used to use a SansAmp GT2 and i have to admit i recorded some really enjoyable solos on that with a CryBaby before it, and the output fed straight into my desk (as was then) then to my old Roland VS1680.
i hope you're sound works out
we're with ya!
best regs
paul d
paul d
tollboothmusic
Old 10-16-2004
Half of 5150=?
Arrow
[QUOTE=Ronan]Actually everything changes with guitar. Recording bass direct with a good bass, DI and player can often lead to amazing results. Recording guitar direct leads to awful results most of the time. On a good day the results with be mediocre. QUOTE]
Sounds like I may have some work ahead...oh the joy! I don't care, It'll be nice to have that baby in my hands this eve. I appreciate the input guys, and I'll be all ears (eyes?) if anyone has more to add regarding this topic.
Yes Manning, I've tried that, but have learned to do all my guitar harmonies without "cheating". In fact I do a lot of it. I'm using Soundforge's plug-ins and they have some octavers and stuff that may come in handy sometime.
My recording partner and singer has been a bit slow as she's a bit of a perfectionist (wha?) and wont allow me to post anything just yet. I do a fair amount of panning and use voluume curve on most tunes. Been staying away from normalizing, and I've gotten quite proficient at putting drum loops together...often from several sources and using time-stretch or resampling. The last tune I posted, I was complemented by several people at my mixing and clean recording. I have a few things that I'd like to send your way just for grins or opinion if you ever care to hear. Cheers!
Thanks everyone!
Last edited by MonkeyShock; 10-16-2004 at 08:10.. Reason: "damnit Jim, I'm just a simple country doctor!"
Old 10-16-2004
Banned
well from what i heard from you before. you have bags of talent.
so i'm sure itll sound great.
Old 10-16-2004
Half of 5150=?
As usual Manning, you're too kind. Thank you for all the help you've been!
I guess we never stop learning and we may never get that "perfect" song, but it sure is fun tryin'.
Old 10-16-2004
Half of 5150=?
Thumbs up
Looked at the POD's...interesting. $199@ GuitCen. Also something by Line6 for about a bill....some sort of amp replicator for guitar to pc. Didn't bother checking 'em out...my pockets were empty. Walked out with a nice Stratocaster with rosewood neck..sweet! Sounds good clean DI. Not liking Magix or Soundforge distortion...just bring up the gain a tad. Who needs food anyway?
  #12
Old 10-16-2004
Banned
i tried the v amp fyi. didnt do it for me.
ms - if were me i might look at those cheap behringer amps .
zzounds,com sells em under 100 bucks. throw a few pedals in front
and mic the sucker and have some fun and blast away.
just an idea for cheap fun.
  #13
Old 10-17-2004
Half of 5150=?
Manning1: That sounds good! I'm always up for some cheap fun. Still, I love the sound of a good clean strat and it seems like blasphemy to alter the sound, though sometimes ya gotta do it. Necessity is the mother of invention...no, wait,...that was Frank Zappa. Peace!-Jody
