vf-160 Users, I have some questions
how long does it take to burn a cd of your project for backup?
looks like no usb or other interface, so it's cd only? what's that row of buttons above each fader? how do you adjust pan on a track, (since there's no obvious pot to turn)? it has 2 inserts, so where do they route to? can you hear the disk running? it has 2 xlr's so, that means it has only 2 inputs of preamps with phantom power? any other things you wish you knew before you got it? the ex version is out, what's the diff? |
That's a lot of questions! The manual may help yuo can find it at
http://fostex.com/index.php?file=support/documents Good Luck Orc |
Check within your quote for my other responses. |
Just a point, if you want scsi specificaly the vf160 has a scsi socket, which is enabled if you run it with earlier versions of the software. Though I believe in later versions they disabled the scsi port for some reason.
The vf160 is also cheeper than the vf160ex and i believe there's little discernable difference in quality or performance? But if you really like silver, then you'll need the vf160ex! It's a quiet machine. It's solid and reliable. had mine 2 years with no probs and it gets heavily used, only hit problems with filling up the disk, but that's my fault. There's a dedicated discussion group here for upgrades and stuff... http://pub15.ezboard.com/fvf16frm1
Online home |
billisa - thanks for the answers. It's now around $800, I think. That's a good price for 16 tracks.
Do you ever use outboard gear w/ tracks you have recorded? like eq or comp? That seems impossible w/ most of the DAW boxes out there. care & glynb, thanks for the info. Manuals are hard to get into w/out the gear, but I look anyway. I think silver is good for contrast. I was using the Korgs and Roland vs2000cd last night. I didn't fall in love w/ any of them. |
I never did check to see if in upgrading my software if my SCSI is no longer functional. I don't use it, but it'd be good to know. |
Honestly though, you should be able to make wonderful recordings with any and all of these machines. |
Yes I use outboard compressor for most things, but i tend to compress as I track, which a lot of people don't like doing. If you want to use outboard gear after you track it;'s tricky because you have to route the recorded track out through the outboard gear and then re-record it to another track, not brilliant really, but it works OK. This is a great machine for the money and i have produced recrodings with it that have been polayed on the radio here in the UK, but you will always have limitations on a stand alone multitracker when compared with PC recording, if you can't live with the limitations then best to go for PC recording in your case, or learn to live with the limitations and work around them. Goos luck with whatever you choose.
Online home |
