Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 09-19-2004
Tyler22 Tyler22 is offline
Junior Member
Tyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond reputeTyler22 has a reputation beyond repute
Sonic maximizer..................
Hi,
I bought a sonic maximizer a while back to clear up my bass sounds on the recording.....well that works great but i just heard that you can use them to clear up or enhance your mix after it done???is this true???if so what does it do?? and how would i hook that up?? out my computer in the maximizer and back to my computer?????thanks for the help
Old 09-19-2004
Ronan's Avatar
Ronan Ronan is offline
Force of Nature
Ronan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond reputeRonan has a reputation beyond repute
Originally Posted by Tyler22
Hi,
Do not do it!!! Well its your recording you can do anything you want, but I strongly discourage it. The sonic maximizer is basically a box that adds distortion to your signal that can make it sound a little exciting at first. It really will mess things up and you will most likely regret using it later.
Ronan Chris Murphy
Ronan's Recording Show My "TV Show" about recording.
Home Recording Bootcamp teaching other guys how to get in trouble
Old 09-19-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
The Sonic Maximizer was created to give an analog recording the same type of harsh scratchiness in the highs that the digital world has been trying to avoid.
While it does *occasionally* fit into a situation here or there, for the most part, yeah... It's like audio-crack. It's a pretty nifty "sheen" that isn't really there, then you get hooked on it until you can't do without it and ruin your life - I mean, mixes with it.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 09-19-2004
Ronan's Avatar
Force of Nature
Perfectly put. I love that.
Ronan Chris Murphy
Old 09-19-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Please, everybody stop using these things! If you have a crappy sounding bass or a crappy sounding bass amp, get a better bass and bass amp. Don't try to cover up the crappyness with some other cheezy piece of crap. I can't telly you how many guys come into the studio with a $150 guitar and a $200 amp and $600 woth of gizmos designed to put a band-aid on a crap sound. It's stupid! If your sound suck, fix the sound. Don't just run it through another piece of junk.
AAAARRRRGGGG!!!! I hate these things!
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 09-20-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Thumbs up
I love you guys!
Old 09-20-2004
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
Proper compression and EQ will fix that bassline. The Maximizer will... funk things out pretty bad. I'm not as against exciters as a lot of people but they have to be used SPARINGLY and on the right things. Sometimes they are okay on high hats or cymbals, sometimes on overheads--when used like 5-10% wet and mostly dry.
Honestly, a good multiband compression setting beats the pants out of an exciter unless the source is really dull and nasty, like someone recorded their overheads with SM57's or something.
