Old 09-15-2004
Robertt8 Robertt8 is offline
1K Silver Member
Robertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond reputeRobertt8 has a reputation beyond repute
SM 57 and SM 58 Interchangeable?
I've heard that they are the same capsule, and the only "real" difference is the ball on top. Is this true? Can you really use the SM58 (which is what I have (2 of) that's why I'm asking) in places where you'd use the SM57? Like snare...or whatever?
Thanks!
Robert Tait
Old 09-15-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Yes, they do sound slightly different but they are good at the same things. Most of the time a 57 and a 58 will sound more alike that two random 57s will.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 09-15-2004
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
After several other members posted pictures of 57s that had been struck by drumsticks, I've taken to using the 58 with the foam inside the ball removed. That probably doesn't make a big difference, but it does look cool.
Old 09-15-2004
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
i've heard the reverse. that the difference between the two is the polar pattern and the 58 has a wider one. i think what makes the 57 a tighter pattern is the phase holes on the sides of it that cancel anything coming through the sides. and what you can do is just tape them up to help reduce the sound that is canceled and resulting in a wider pattern. never tried it, but this is what i've heard you can do. i could be completely wrong
www.redlabaudio.com
Old 09-15-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Never ever heard that... they're the same capsule, so there's no basis for a difference in polar pattern...........
Old 09-15-2004
1K Silver Member
umm...so you'd say they could be used interchangebly?
Old 09-15-2004
yeah i know...like i said this was a theory that was told to me. i never tried it to prove it
www.redlabaudio.com
Old 09-15-2004
Pretty much...... the difference in sound comes from the difference in casing and the ball-end on the 58 (since the ball end limits the proximity to the capsule - unless you unscrew the top half....)
Old 09-16-2004
1K Silver Member
thanks! case closed.
Old 09-18-2004
fenix fenix is offline
1K Silver Member
fenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond reputefenix has a reputation beyond repute
theyr'e not the same.
Old 09-18-2004
Bulls Hit Bulls Hit is offline
Been Here, Posted That
Bulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond repute
Unscrew the top of the 57, take the ball off the 58, & they is identical
  #12
Old 09-18-2004
They ARE....... same capsule, slightly different casing/housing......
  #13
Old 09-22-2004
mattamatta's Avatar
mattamatta mattamatta is offline
Force of Nature
Location: I told my friend that his anus was so big, that he had to get a restraining order for the local caving club.
mattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond repute
Mathematically, they are almost the same. There is only a 1.73% difference.
  #14
Old 09-23-2004
how the HELL did you figure that out?? or am i missing the joke?
www.redlabaudio.com
  #15
Old 09-23-2004
mattamatta's Avatar
Force of Nature
Simple I merely devided 57 by 58, and converted it to a percentage difference.
Feel free to quote me on that (just dont make me look like TOO much of an idiot )
  #16
Old 09-23-2004
1K Silver Member
Talking
I almost posted the same question...I figured he was some kind of engineer with a complicated mathmatical formula...as it turns out his formula was quite simple
  #17
Old 09-23-2004
hahaah....jokes on me
www.redlabaudio.com
  #18
Old 09-23-2004
mattamatta's Avatar
Force of Nature
I'm not an engineer yet, but I'm a student on my way toward a BS in electrical engineering....
But I think I already have a BS in BS (haha! it's a pun!.... ok ok, I'm sorry, puns are "very" "humorous")
Anyway, yeah, I made that up one time on the harmony central forums when a similar question was being asked, and I found it pretty funny.
