Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 09-11-2004
Greykitkat36 Greykitkat36 is offline
Senior Member
Greykitkat36 is on a distinguished road
Tascam 424MKIII Problem With recording.
I have a Tascam 424MKIII 4-Track recorder. Iam recording drums, bass, piano, and 2 guitars. The recorder records fine, but on the playback it seems the track (drums normally), playback alot softer than it should be. Is this a mic problem, or is it my 4-track recorder? Much help is appreciated.
Old 09-12-2004
SMOKINDOG SMOKINDOG is offline
Newbie
SMOKINDOG is on a distinguished road
Cool drums
It may be that you did not set the trim high enough while recording? I have had this problem also.
Old 09-12-2004
DigitalSmigital's Avatar
DigitalSmigital DigitalSmigital is offline
A slice of analog pie?
DigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond reputeDigitalSmigital has a reputation beyond repute
Recording is an artform in itself.
Mic placement on acoustic instruments is a huge challenge. You want to get the strongest possible signal on tape, without sacrificing the dynamic range inherent in a great performance.
What to do? Describe what you have done and we'll give a shot at improving it.
Old 09-15-2004
Seeker of Rock's Avatar
Seeker of Rock Seeker of Rock is offline
InLovingMemory..EZ_Willis
Seeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond reputeSeeker of Rock has a reputation beyond repute
You have a monitor "cue" for each track you record on. It is the effect 2/cue knob. Make sure that is turned up on the track that is soft. If your recorded level was soft, your level LED meter would tell you. It would only light up one or two segments. If that is not the case, I'll bet it is your monitor cue level.
