saving mix properties for next session
I am using an Alesis HD24 for live recordings, loading the recordings into Cool Edit Pro 2.0 for mixing. I found out the hard way that it is best to break up recordings on the Alesis into 15 to 18 minute chunks. These chunks can contain 2 to 5 songs that I mix, effect, compress...ect. on my computer using Cool Edit. The bands that I am recording are playing 30 minute to 1 &1/2 hour performances....therefore I may have 2 to 6 chunks of audio from the same band....meaning that the mic placements, instrumentation ect never changes. My question is this.....is there a way to save my changes to the tracks (compression, reverb, volume ect) from one chunk of audio to the next? Everything about the recording stays the same....if the bass needed 4 to 1 compression in the first chunk it will need the same treatment in all chunks. If there is a way to save all the changes by loading a different chunk into the same session parameters, it would save me countless hours of processing time.
thanks in advance bluesman714 |
Look up how to create a default session - also you can save effects racks as presets for later reuse.
My manual does not tell me What? a default session is used for.....only how to create it....It also does not tell me how to load the "new" tracks into the default session......
Help me out! |
Re-reading your post I suspect you're not using realtime effects in the multitrack view. Those effects are applied to the whole of the track, non-destructively. Don't apply effects in edit view unless you have to. Forget about the default session for the moment, concentrate on effects in multitrack.
Read up on "scripts & Batch processing." Very useful for what you're doing. Basically, it allows you to script out a sequence of effects that you want to apply to a track. Like for the vocal, you could compress it, then EQ it, then De-Ess it, then add Reverb all at one time once you've done it once and scripted it out. Handy feature...takes a little while to get familiar with, but it's worth the time.
http://www.changehiphop.com/images/pics/Signature.jpg Preview of the new Album here!!! Mixing and Mastering services for your project, contact change@changehiphop.com |
Post back if you run into problems.
Fantastic, Chris. I was completely unaware of this capability. Stupid me...lol..
One question before I try and fail, will it record my Noise Reduction settings, or is it like saving a favorite, where it just won't work because of the variables? Thanks again.
