mixing down
hey,
so i have all my tracks the way that i want them with all the envelopes and volumes done....so now what, how do i get all these tracks with all the envelope changes onto a cd?? and how do the files get smaller, cause at the momment they are huge and you wouldnt be able to fit many on disk thanks, C |
what software are you using? you need to bounce them down as a 16 bit, 44.1Khz Wave file.
www.redlabaudio.com |
oh, i have sonar 2.2
how do you do that,please, thanks, C |
i am not familiar with sonar, but once you get a wav file, you will need to encode that to an mp3 file. There are a lot of free programs out there, just search google.
thanks a bunch for your help,
if anyone else has something to so it would also be appreciated. cheers again C |
Hey C,
Check your post in Cakewalk forum. Try not to cross forum double post. ![]() Jaymz
Keep Rockin' and Rollin'...
Once I have mixed all the levels, stereo positioning, EQ adjustments, and effects, I SAVE it, then bounce it all to one track, delete the original tracks, save it under a DIFFERENT name indicating that it's a mixed down version, normalize, compress (if needed) and finally, EXPORT AUDIO (under the FILE dropdown menu) to a wav file. You then can burn it to disc and take it around and monitor it on different players to determine what changes may need to be made. I hope my process helps you find a process that works good for you.
It should cover this in the manual. RTFM
Why would you delete the original tracks??????????
Because if that mix-down is a keeper, I prefer to lessen the burden it has on my processor by removing the rest. I've got a fast computer, but I like to have a file devoted exclusively to my mixed down version. It's just my preference. The song pops right up when it's not trying to load 16 to 20 other tracks. Like I said, it's just the way I prefer to do it. Please let me know if there's a better way. I soak up everything I can from these forums.
#12
Maybe I misunderstood you, you mean you remove the original tracks from the song file (or whatever it's called in your program), but keep the original tracks on your hard drive somewhere. This is fine, and is recommended for the very reason of easing the load on your processor. Sometimes folks will even "print" tracks with effects (such as compression) onto a new track/wav file, so when they continue to mixdown, they don't have to instantiate that plug-in. But I would NEVER remove original/raw wav files from my PC (unless the take/performance itself sucked!)
Good luck! Quote:
