Old 08-23-2004
punksoholics punksoholics is offline
Newbie
punksoholics is on a distinguished road
sonar 3 producer edition metronote question
anyone know how to hear the metronote on the headphones, my laptop is playing it on the pc speaker and im trying to record a mic'd up acoustic but you can hear the metronote on the pc speaker.
Old 08-23-2004
bfoundation81's Avatar
bfoundation81 bfoundation81 is offline
Senior Member
bfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond reputebfoundation81 has a reputation beyond repute
Get rid of sonar heheheh lol no just kiding um i had same problem i got rid of sonar but let me try and remeber i will get back to you its something real simple too i wish i had it still i could find it quick!!
Dont be mean to me!!!!!!!!!
Old 08-23-2004
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Ah, might you mean "metronome?"
I'm at work, but IIRC in the Metronome menu there is a choice of selecting outputs for PC Speaker or MIDI. Choose MIDI (assuming you have a sound card with with an onboard midi synth, or an external midi source you can use).
Old 08-23-2004
minofifa's Avatar
minofifa minofifa is offline
1K Silver Member
minofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond repute
ya, as cool as Sonar is, if you don't have the right setup, the metroNOME is junk. The best way to do it, i find, is to open a MIDI track and insert 4 1/4 notes, then groove clip it and drag it out. Then assign that midi track to the edirol softsynth and use a drum beat that sounds good to you. Finally save this as a template so you don't ahve to set it up again.
www.sanijav.com
www.myspace.com/sanijav
Old 08-23-2004
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
The only other thing I would add to Minofifa's advice would be to NOT use a cymbal or hi-hat hit for the metronome. These types of hit are very high-pitched and are more likely to bleed from your headphones and end up recorded on the acoustic track. Try getting that out without effecting the guitar's tone!
Instead, do what I should have done, and use a low-pitched percussive tone instead - something like a claves hit.
Ciao,
Q.
<insert something witty here>
Old 08-24-2004
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Lightbulb
Originally Posted by Qwerty
Instead, do what I should have done, and use a low-pitched percussive tone instead - something like a claves hit...
...actualy, it's more cowbell that you need, budy.
Jaymz
Keep Rockin' and Rollin'...
Old 08-24-2004
Qwerty's Avatar
1K Silver Member
Jaymz
Actually, I got too much bleed with the cowbell at levels the drummer could play against. It was the claves hit that did the trick.
Q.
Old 08-26-2004
RyantFromHC RyantFromHC is offline
Newbie
RyantFromHC is on a distinguished road
add a DXi synth, use the included Edirol one, set the thing to a standard drum kit, and create the metronome with a midi track, the synth has metronome sounds. then SAVE THE THING AS A TEMPLATE or go though that every time
Old 08-26-2004
dachay2tnr's Avatar
One Hit Wonder
Ah, that's great... but didn't Minofifa say that about 5 posts earlier???
