Old 08-20-2004
sandro perri sandro perri is offline
Newbie
sandro perri is on a distinguished road
file degradation
hi...this is my first post on this wonderful site...i wish i had known about it earlier...
wondering if anyone can tell me about the possible dangers of continually saving a project in Sonar as a .BUN, burning it to disc, and then re-loading it onto your hard drive for further work. does this degrade the audio data in any way?
thanks,
sandro
Old 08-20-2004
Sklathill Sklathill is offline
Soundcard Junkie
Sklathill will become famous soon enough
Aas long as there are no errors that crop up upon reading of the CD, there will be no errors.
Old 08-22-2004
Newbie
i wasn't actually referring to disc errors, but more to the file degradation that occurs when you burn data to a disc. for example, when you work in 24-bit and burn an audio cd, you are degrading the audio down to 16-bit. my question is: does burning the cakewalk .BUN files as DATA cause this same bit-loss to happen to the audio data?
thanks,
sandro
Old 08-22-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
nope, see your other thread for your explanation
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 08-22-2004
Porter's Avatar
Porter Porter is offline
aka WookieMan
Porter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud ofPorter has much to be proud of
thanks,
sandro
sandro,
The only thing which you could have a problem with is a corrupted BUN file. It doesn't happen often, however when it happens, depending if you have a back up, it could be painful.
When using Sonar, it's best to use the folder per project options. That way you just burn the folder to the disk, that way if any part of the file corrupts you won't loose all the audio. Whilst it does mean more files, it also means that if one corrupts you would only have a glitch in that file, not the whole project.
Just a suggestions,
Porter
Old 08-23-2004
Newbie
porter,
i didn't know about that option - thanks for the tip!
Old 08-23-2004
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
If you are recording at 24 bit and then burn the .BUN file (or the Per-Project folders options from Porter) to a CD, then the files are NOT converted to 16-bit.
Therefore, you have nothing to worry about.
You only need to convert down to 16-bit when you are preparing an audio CD for use in a music CD player.
Ciao,
Q.
<insert something witty here>
