Old 08-18-2004
Bob's Mods's Avatar
Bob's Mods Bob's Mods is offline
Force of Nature
Bob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond repute
Sample Paragraphic EQ Settings...
Could anyone(s) share your common track parametric EQ settings for acoustic, electric guitar and vocals. It might be interesting and helpful to compare notes on this.
I typically set one node around 3k Hz with a bandwith/Q of 4. It's typically pulled up +9 or +10 dB. I also add a low cut around 150 Hz. I have found if I don't do this, when I play back the track, it won't sound like it did in the monitors when I recorded it.
Although I have checked my system for a flat response curve and it is indeed flat. I have never been able to figure out why the playback is not an exact copy of what I was listening to in my monitors while recording. Has anyone else experienced this oddity?
This EQ setting is strangely similar to the curve of how the human ear actually hears audio bandwidth.
May You Live All The Days Of Your Life
Old 08-18-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Common EQ settings?
That's about the equivalent of asking how long a piece of string is......
There's no "common" settings -- it always depends entirely on the context of the signal you're dealing with at the time.
You can look at the frequency range of a given sound source, and use that to tailor certain adjustments, but no signal is ever identical enough to another to allow any concept of "common settings".......
Old 08-18-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
What are you playing it back through? 10db of 3k is a huge difference. There has to be something out of whack.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 08-18-2004
Bob's Mods's Avatar
Force of Nature
I use a high quality small boom box for highs and two JBL bookshelf speakers connected to a small Carvin power amp for the lows. I know it's not ideal but it plays back commercial CDs with out any problems. The commercial stuff sounds dynamic and clear. I've got some blankets on the walls of my room and a carpet on the floor so the room is not very reflective.
By being radical with the eq my stuff sounds closer to the commercial stuff. Without the eq it seems impossible to match.
Without the eq, the playback doesn't sound the same as when I recorded it using the same monitors. I have never been able to explain this. Maybe my monitoring is that F****D up?
I've tried numberous pieces of gear and it always comes out the same. The only thing I haven't changed is my sound card which I only use for a S/PDIF connection. Is there a possibility that the soundcard could be messing with my digital?
Old 08-18-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
It's likely that something is terribly, terribly wrong somewhere if you're doing that. I think most would consider 3-4dB and "extreme" increase.
Anything about your signal path you'd like to share? Mic? Prreamp? Sample rate & word length?
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 08-19-2004
screws screws is offline
Junior Member
screws is just really nicescrews is just really nicescrews is just really nicescrews is just really nicescrews is just really nice
I myself prefer an "equametric paralyzer" to a "parametric equalizer". But that's just me...
S. Cruz
Cruzified Music
Florida
