Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 08-15-2004
Jayme's Avatar
Jayme Jayme is offline
Senior Member
Jayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond repute
Exclamation IIIIIIT!!! What's wrong with it now!!!???
After taking the Roland XP 10 apart, putting in a new battery and then putting it all back together, I've found out that the modulation and pitch bend controls don't work!!! but I didn't touch them when I opened it!! please help....
anyone??!!
Drugs - u = Drgs
Old 08-16-2004
CGibson CGibson is offline
Senior Member
CGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond reputeCGibson has a reputation beyond repute
Cool
anyone??!!
Did you try the factory reset?
"Press UTILITY. Use the VALUE + or - to select INITIALIZE, then press ENTER. Use the VALUE + or - to select FACTORY PRESET, then press ENTER."
I borrowed this from arcaxis that borrowed it from Roland that borrowed it from Japan that borrowed it from somebody way smarter than me.
C
Old 08-16-2004
Jayme's Avatar
Senior Member
Yes i did , i forgot to mention that, but it still dosen't work!!!!
Any ideas???
Drugs - u = Drgs
Old 08-16-2004
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
Check your ribbon cables and don't forget the static strap.........
Old 08-17-2004
Jayme's Avatar
Senior Member
Eh...? Wa...? Sorry i don't know what they are but if you could explane then i would be very full of grapes!
Drugs - u = Drgs
Old 08-17-2004
arcaxis's Avatar
arcaxis arcaxis is offline
Force of Nature
arcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond reputearcaxis has a reputation beyond repute
The ribbon cables are the flat multi-conductor wiring that makes the connections from board to board. These usually have connectors on the ends that plug onto the board or it may have no connector and just be like a thin flexible circuit board with copper foil that makes the connection. They do occasionally get loose and fail to make connection. Boingoman is simply saying check to make sure all the connectors are plugged firmly to its mating connection on the circuit boards.
The static strap is a device you would wear on your wrist with a wire on it which attaches to something which is grounded. As you move around you can build up a charge of static electricity which could damage electronic components. The strap drains off the static charge.
Also make darn sure you've got the board unplugged from the wall if you go back in pokin' around !! Electricity hurts like the dickens....
If you have any friends that frequently works on the hardware insides of a computer, I would recommend enlisting their assistance. Much of what goes on inside a keyboard is very similiar to a computer and someone used to working in a PC might be able to spot something right away.
