Go Back   Home Recording > User Forums by Brand > Cool Edit Pro / Adobe Audition Forum
Reply    Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 08-12-2004
7TPFN 7TPFN is offline
Newbie
7TPFN is on a distinguished road
Drums mastering question...
I have a song that was recorded in two parts. The only way you can notice is the first half of the drum track has a bright snare. The second half has a dull snare and faint kickdrum but it's not THAT bad. Is there a way to accentuate those two (snare and kick) without making that half of the track sound "bright" in all areas?
Old 08-27-2004
gasal69's Avatar
gasal69 gasal69 is offline
Junior Member
gasal69 is on a distinguished road
session or mix
Is there a way to accentuate those two (snare and kick) without making that half of the track sound "bright" in all areas?[/QUOTE]
Do you still have CEP-session of that song?
Old 08-30-2004
Newbie
Yes...
Yes I do still have it. I haven't made any changes to it at all.
Old 08-31-2004
gasal69's Avatar
Junior Member
Hard way
Try this:
Start a new session,
Insert your drum track in it twice.
Track 1 = drum (your original file)
Track 2 = drum (2)
Rename drum (2) to DrumHelp or whatever (Go to edit window and save as new name)
Back to session multitrack window and move this DrumHelp to track 3.
It means that you leave track 2 as an empty track
Split this new DrumHelp so many times you have need for good snare parts. (Split it just beside snares).
Move good parts snares from this multisplitted HelpDrum to track 2 just below bad snares from track 1.
(take your time and do timing by using zoom tools)
All other parts of this multisplitted track can be deleted and track 3 will eventually disappear.
Bad parts of your original which is placed to track 1 must be turned to volume = zero by envelope tool.
This green envelope line is going to look like this:
. __ . . ___ .
_| .|__| . . |__
Everything is going to look like a puzzle but be patient man.
Edit volume envelopes on this small parts of puzzle. Make sure they never start and end with 100% volume.
Make it look like this:
`. ____
_/ . . . \_
Mix down all files to new one track and save it as NEW DRUM. (When you are satisfied with the result).
Open your old Session and replace your old drum track with this new one.
I know this sounds VERY COMPLICATED, Too much work, Sure!
Sorry! English is my fourth language
I hope someone else will come and tell as about better ways. I’m looking forward to.
Good luck!
Old 08-31-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
Get a program like drumagog and replace the kick and snare. You can replace it with samples from the part of the song that sounds good.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 09-05-2004
BlackoutSP BlackoutSP is offline
Newbie
BlackoutSP is on a distinguished road
Lightbulb Are you all massacists'?
how many tracks were the drums recrded with? if the snare and kick had individual mics, and were recorded in there own channel (as they should be, ALWAYS, find a way to do this, buy a four track interface and send snare in one, kick in two, and the rest in an L/R mix) if you are laying down drum tracks, you MUST do it with at least four tracks, so taht you can do post on the kick and snare carefully. if the snare and kick (or even just one , will make life simpler) had their own channel, let me know, and i'll get back to you with some EQ and compression settings that should fix all of your problems.
-Keith
Old 09-05-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Originally Posted by BlackoutSP
...i'll get back to you with some EQ and compression settings that should fix all of your problems.
Hmmm... without actually hearing the tracks, how exactly will you accomplish this feat? And even if you heard the tracks, you'd need the context of the rest of the song as well............
