Old 08-11-2004
kiira kiira is offline
Junior Member
kiira is on a distinguished road
my tascam, the story continues
hey ya'll,
hmmm well it seems like my channel strips are ok on my M512 because I can send mic or line in through them all and monitor off aux 1,2,3 or 4 but if I just use the MON mode switch alone i have no monitor signal on 2,6,7 or 8. So like that means it's something in the monitoring cicuit... either in the wiring for the circuit on each of those strips, the connectors or in the monitoring module itself I guess. next I'll try the outputs to all the channels and then I guess that will reveal all the problems, hopefully none. If it's just the monitor capability on those four channels I can prolly track it down. keeping my fingers crossed, and my eyes too... all those wires!
We are not a 5th rate band. We're a 3rd rate band - Michael Nesmith
Old 08-11-2004
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Talking A happy repair success story to give you inspiration!
One of my M312B mixers, (I have two of them), had an intermittent master stereo buss that was intermittent on the right channel and the previous owner, in an attempt to fix it, had the 100 mm faders changed and because the problem didn't show up all the time, he thought he solved the issue.
When I bought it off of him, it was working well for quite some time and then the issue showed up again!?
In frustration at the appearance of the problem, I rapped my knuckles against the top of the board close to where the power switch is on the top right corner and low and behold, hitting it, made the channel come right back!
It's the old story of how your dad used to whack the side of the TV to make it work and this turned out to be the same low tech solution.
Cheers!
Old 08-22-2004
Vintage TX's Avatar
Vintage TX Vintage TX is offline
Senior Member
Vintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond reputeVintage TX has a reputation beyond repute
You were lucky Ghost
A couple of times I have found decks with strange dents on the sides, hmm
Vintage TX
