Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 08-03-2004
Semt-X Semt-X is offline
Newbie
Semt-X is on a distinguished road
Direct hearing of plugins??
Is it possible to hear a plugin directly, instead of recording a track and then put the plugin over the track?? Im running on a ESI WaveTerminal 192M and i have done a lot of things but nothing seems to work? Anybody help me out, maybe there a some setting wrong, im running on ASIO 2.0
Old 08-03-2004
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Some instrument plugs yes, but how could you ever hear a compressor without a signal? Or a reverb? Get my drift?
Old 08-04-2004
Newbie
i get your drift, but when i want to hear some plugs directly (insert?) nothing happens?? Also with Native Instruments Guitar Rig, i wanna hear this one directly but nothing happens to my signal. I only hear the signal as it originally comes in, dry guitar signal......
Am i doing something wrong here?
Also with reverb plugs, notrhing seems to happen.
Old 08-05-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
I use Nuendo among other programs, and to hear the result of an effect in real-time without recording it ......
Setup an Audio track and arm it for record and turn on monitoring.
Put whatever effect/effects I want to hear in an Insert.
It's kinda cool ... I'll have a few mics hooked up to their own tracks and load up Drumagog in the inserts and tap on the mics with my fingers and viola .... Drums play.
I've never used VST2.0 so I can't tell you exactly how it would be set up, but it seems as though you should be able to do the same thing if it allows you to set up a blank audio track, arm it to record and turn on monitoring for that track. My be called direct monitoring ... or live monitoring ... or live input processing ... or something to that effect.
HTH
-Ken
~It all works out in the end~
