Old 08-02-2004
Mongoo Mongoo is offline
Dedicated Member
Mongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond reputeMongoo has a reputation beyond repute
Some good quality cable making do-dads
I'm going to buy ruffly 300+ feet of bulk cable and was wondering if anyone could post some links or give out brands/models for some quality cable making gear.
I figure I'm going to need:
- Wire Cutter
- Wire Stripper
- Solder
- Welder (I have one but I'm not sure if its any good)
- Heat shrink
- Flux? (Don't really know what this is)
- Hemostats (again, don't know what this is)
Any help would be great.
Thanks
Mongoo
Old 08-03-2004
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
When making audio cables a welder and heat shrink are not things that I would include on my list.
You WILL need plugs/jacks/connectors and a table mounted 'third hand' comes in mighty handy as well. This is a simple thing with two alligator clips mounted to a base --- it holds the wires in place while you solder.
You don't say whether you are trying to make speaker cables in which case you should buy unsheilded cable, or instrument cables in which case the cable should be sheilded.
Either way, Google up a good retail musical electronics supply house and you should be able to find everything there. I got my last 'third hand' at Radio Shack.
Hemostats are surgical tweezers that look more like scissors and lock together. The third hand serves the purpose that a hemostat would serve.
Old 08-03-2004
Chip Hitchens Chip Hitchens is offline
Junior Member
Chip Hitchens is on a distinguished road
Making cables is pretty easy and cheap. Here's a site:
http://www.recordingwebsite.com/articles/cables.php
I'd get a cheap combination stripper/cutter. Mine is a Craftsman from Sears, which is probably far from the best but has a lifetime, no questions asked exchange policy.
Use rosin core solder. The kind from Radio Shack, not the thick stuff in the plumbing section. A cheap low wattage soldering iron will be fine, and you can use it for electronics work if you ever want to get into that. The big guns are too hot for electronic components. Just make sure you have a stand for whatever you get, because you won't be able to just lay it down when it's 400 degrees.
Heat shrink is nice but not required if you solder neatly. Flux is not used with this kind of soldering. Hemostats, also called forceps, are little surgical clamps that can be useful for holding wire, but anything will do. You'll find at some point that you could use one more hand to hold everything, but you will probably be able to rig something.
Old 08-03-2004
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
Yeah, I'd skip the heat shrink personally. As far as the welder, that would be overkill, bigtime. I use a soldering station made by Weller, it works great.
A clamp is very important, as it will help you hold the connectors in place while you work on them. I use a panavise. Origianlly I used the alligator clips but things kept slipping and it was overall a hassle. The panavise has really allowed me to speed things along.
Neutrik connectors are excellent and easy to work with. I use various cables depending on what I'm doing, but usually it's Canare cable. I've also used Horizon and Connectronics cable.
Old 08-03-2004
boingoman boingoman is offline
moldin' oldie
boingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond reputeboingoman has a reputation beyond repute
For making a bunch of cables at once I made a little jig out of a piece of 2x4 with holes to hold 1/4" jacks and XLR plugs so I could have 10 in a row, all ready to solder.
Old 08-03-2004
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
you probably should also get a DMM (Digital Multi Meter). This way you can make sure you soldered the cables correctly. You don't want to wire an XLR cable, close it all up, and find you switched the hot and cold pins on one end. Also, I thought the Flux was the melted solder...am i wrong? So in short what you'll need (or what i use):
-A soldering iron (around 35W will do)
-wire strippers and cutters
-needle nose pliers
-a screwdriver
-DMM
-solder (60/40 rosin core)
-20-23ga. 2 conducter/shielded mic cable for balanced
-XLR Male/female, 1/4" TRS or TS, RCA connectors...etc.
-something to hold the connectors (you also can get a block of wood and cut holes in it to match the size of both connectors and stick them in there)
-a sturdy surface to work on
www.redlabaudio.com
Old 08-03-2004
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
And a damp sponge to clean the iron's tip.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 08-03-2004
jonnyfive jonnyfive is offline
Newbie
jonnyfive is on a distinguished road
Flux is a paste which prepares the surfaces and helps the solder bond. If your using rosin-core solder (which you should), the 'rosin-core' is actually the flux and no extra will be needed.
Old 08-03-2004
ah...okay, gotcha. thanks man
www.redlabaudio.com
Old 08-04-2004
Good suggestion about the cable tester, that should be required equipment when making cables. Sooner or later you will get the wires crossed. Not sure if a digital multimeter is necessary though. I use the EbTech Swizz Army cable tester, a great piece of gear.
Old 08-04-2004
yeah, you can just get a cable tester if you want. however the EBTech sells for around $120 bucks. You can get a DMM for about 50 bucks...AND be able to test any other audio gear, batteries, wall outlets, circuit boards and components, etc.
www.redlabaudio.com
  #12
Old 08-05-2004
That's list price on the EbTech I think. You can find it for less, but there certainly are less expensive alternatives. The point I think is to have some way of testing the cables after they are made, that's important.
  #13
Old 08-05-2004
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
Solder Pot!
If you have a lot of soldering to do, get a SOLDER POT. Strip all your wires beforehand, all the same way, and then just dip them in the pot with a single hand - very quick and very even tinning of your wires. The POT comes in very handy for pre-tinning XLR plugs also - just dip and you're done. If you have a lot of work to do, this is the quickest and easiest way to go.
No need for a soldering station - might look great with its little red rocker switch and different heating options (which you don't need anyway), but for this application, your money's better spent on something that will ease the workload, like the solder pot.
40 watt soldering iron (no more, no less) for making the final connections.
A 'soldering gun' looks cool, but not really suited to this kind of task. Plain old 'wand' type works best.
As for strippers, I like to use two kinds:
Crimp tool type - gives you a series of holes for different wire gauges. The only way to strip a shielded cable.
Gun type - great for the inner conductors as they are so quick. They will wreck a shield though, hence the need for both types.
Silver 4% (lead-free) solder is nice, but a little trickier to work with. Plain old 1mm solder is fine.
  #14
Old 08-05-2004
Force of Nature
Solder and flux
No need for flux, unless you're plumbing pipes.
Most any electrical solder contains flux already, which makes the solder flow more readily around its contact area at melting point.
  #15
Old 08-05-2004
Force of Nature
The secret life of solder pots (cont)
Another thing to consider is this:
The of the trickiest things about soldering is the fact that you have to:
1. hold the connector
2. hold the wire
3 hold the soldering iron
4: hold the solder
If you are making up XLR cables particularly, the solder pot shines in this respect.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
