Old 08-02-2004
cjacek's Avatar
cjacek cjacek is offline
Analogue Enthusiast
cjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond reputecjacek has a reputation beyond repute
Question Tape for older TEAC R2R machines ..
I see that so many of the older TEAC reel machines, the ones from the 70's for example, use Scotch and similar tape formulations. Would a Quantegy 456 be compatible with such a recorder ?
Thank you.
Daniel
Old 08-02-2004
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
456 should work without issue.
Cheers!
Old 08-03-2004
cjacek's Avatar
Analogue Enthusiast
Cheers!
Ok, thanks!
Daniel
Old 08-03-2004
Uli_the_Grasso Uli_the_Grasso is offline
Newbie
Uli_the_Grasso is on a distinguished road
Most iron oxide tapes do not differ much but stay within a 1dB margin. But when you have a crome oxide or a sterling iron tape, you will hear the difference at once, because the bias set on your machine will be totally off.
