Old 07-31-2004
wildflower soul wildflower soul is offline
Senior Member
wildflower soul is on a distinguished road
Static on tracks 1 and 2
On my 388, Ive been doing drums at the same levels for a while and no problem including today then all of a sudden on the snare and kick tracks theres a tiny bit of static. I Thought it could be the level but I dont think so. Could it be the heads?
Because it only does it on track 1 and 2
Old 07-31-2004
Uli_the_Grasso Uli_the_Grasso is offline
Newbie
Uli_the_Grasso is on a distinguished road
Have you thoroughly looked for dirt? Do you have a sound head demagnetizing tool?
Old 07-31-2004
Senior Member
i cleaned and demagnitized the heads. yes. if the heads are infact shot, i luckily have a set of brand new heads not even opened yet
Old 07-31-2004
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
Might also be something as simple as a staticky pot or cable on an insert point?
Try rotating all the pots that are on the first two tracks and see if there isn't just a cobweb or two in there itching to get out!
Cheers!
Old 08-03-2004
acorec's Avatar
acorec acorec is offline
Banned
acorec has a spectacular aura aboutacorec has a spectacular aura aboutacorec has a spectacular aura about
This is a bad cable or a dirty pot. The real test is to record something like a soft synth, then drums. If the static goes away on the synth but appears on the drums, the cables or pots are bad/dirty.
Old 08-06-2004
Senior Member
what about loosing tracks? i seem to have lost tracks 6 and 8 on a reel i recorded a while ago. they are sortof there but you have to turn the level to 10 and then it squeels and sounds awful and only comes in every 2 seconds. On old and new reels. When i demaged at first I could hear track 6 a tiny bit, but then it went away. So i demaged again and its still not working i recorded a few test tries on track 6 and they all come in all distored and horrible sounding and fade in and out
So my 388 is offically now really messed up
Old 08-08-2004
Senior Member
on the heads it appears as though a black mark is missing on the 6th line. which may explain why im getting only distored signal on track 6 playback?
Old 08-08-2004
A Reel Person's Avatar
A Reel Person A Reel Person is offline
It's Too Funky in Here!!!
A Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond reputeA Reel Person has a reputation beyond repute
Arrow It's hard to tell, with that description, whether the head's actually damaged, or not
Have you tried opening up the top of the unit, and reseating the audio cards?
Sometimes that helps, as sometimes the connectors can go marginal from oxidation. If this is the case, usually removing and reinserting the cards helps.
I don't know if you can show a macro photo close-up of the head. I'd be interested to see what you're looking at, in the possible defect on the head.
Old 08-16-2004
acorec's Avatar
Banned
A last ditch effort:
Use trash tape. Color the playback and record heads with an indelible ink marker. Let dry. Now, play the trash tape for a minute. Take the tape off and look at the heads. The tape should have taken off the marker ink. Now, look at the heads. The ink should be gone exactly in the center of each head. The shape of the clean area on each head should have dead parallel lines (up-down,with each other) and be really narrow about the center. If the placement is off-center, the width is large, and the shape "hourglass" then it is probably time for a re-lap, or new heads.
Old 08-19-2004
Senior Member
it took away excactly in the center.. perfectly
the guy who sold it to me included a set of brand new heads saying it needed them badly and that was a year ago and he said he bought the machine in 1985.
im gonna take it to a tech whos worked on my gear before, ill report back what the problem was. rewind and FF are going way slower than normal now too heh just to add to the problems its worth it to me to have it fixed though
Old 09-01-2004
Senior Member
my ex girlfriend bought me 2 cans of air duster earlier today, so i dusted the unit thoroughly(even though it has a cover on it when im not using it). i dusted the fader and everything and track 6 plays all of a sudden and rewind works at normal speed again. how great! and embarassing
  #12
Old 09-01-2004
French Mofo
Cheers!
Well, I'll be a monkey's uncle!
Glad to hear its working again!
Cheers!
