Old 07-28-2004
BrettB's Avatar
BrettB BrettB is offline
1K Silver Member
BrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond repute
CHeap Headphone amp
Hi all,
This is an easy one: what is the cheaspest headphone amp available? I don't need mulitiple inputs?
any thoughts?
www.protoolsforum.com
The board for all Pro Tools (LE) users!! Finally back online.
Old 07-28-2004
Garry Sharp's Avatar
Garry Sharp Garry Sharp is offline
Lost Cause
Garry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond repute
Behringer HA4700 or the Samson one - prices very similar.
Old 07-28-2004
Twitch's Avatar
Twitch Twitch is offline
Senior Member
Twitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond reputeTwitch has a reputation beyond repute
Rolls, Art and Samson make a 4 channel headphone amp which is the cheapest you can buy either one for $59.99 thru any music outlet store(musiciansfriend.com, zzsounds.com, etc..)
http://www.myspace.com/infamoustwitch
Music is a moral law,
it gives wings to the mind, a soul to the universe
flight to the imagination, a charm to sadness
a life to everything,
Plato, 400 B.C
Old 07-28-2004
Chip Hitchens Chip Hitchens is offline
Junior Member
Chip Hitchens is on a distinguished road
How many outputs? If you're only talking about one, I made one of these for about $25 including the case and it smokes anything under $100. Burr Browns baby!
http://headwize.com/projects/showfil...=cmoy2_prj.htm
Old 07-28-2004
Twitch's Avatar
Senior Member
I'm talking about 4 outputs
Plato, 400 B.C
Old 07-28-2004
Leeking's Avatar
Leeking Leeking is offline
TrueVine Studio
Leeking will become famous soon enough
I have the Rolls HA43 (4outputs) ~$55 ... good stuff...
nowadays Art, Yorkville has the exact copy for around $30....
Leeking
My songs
My studio pics
Old 07-29-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
If you are the DIY type and have an old stereo receiver you can build a multi-headphone amp.
Build a headphone patch panel that consists of 1/4" stereo jacks, as many as you need to get a headphone feed to everybody.
Wire each jack through a separate 2.2K 1/2W resistor in series with the positive leads for L and R channels.
With the 2.2K common resistor value you should be able to run headphones with impedances from about 4 ohms on up to a couple hundred ohms without any problems. Good idea to use impedance matched cans, though if you don't install separate volume control L-pads as described below, or the guy with the 150 ohm cans will have lower volume while the guy with the 8 ohm cans will get blasted.
Wire the paralleled jacks and resistors to the SPKR terminals of the unit.
You can easily and safely run at least 20 sets of headphones maximum this way, and most don't need that many.
If you need separate volume control for each headset simply wire in L pads, 8 to 16 ohm wire-wound dual pots designed for stereo speaker fading which you wire in after the resistors to each headphone jack.
L-Pad goes between each resistor and it's corresponding output jack, pin 1 to hot, pin 3 to Common and pin 2 to the jack output.
Must be done to each channel.
~It all works out in the end~
Old 07-29-2004
BrettB's Avatar
1K Silver Member
sorry, I think I'm not handy enough for that
I'll go for the Behringer one, thx for all the hints everyone!
