Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 07-27-2004
solarscar solarscar is offline
Newbie
solarscar is on a distinguished road
Using a compressor. Insert or use the aux sends?
When using compression/limiting/gating is it best to "insert" them to the channel you want are can you use the aux send/return on say, a compressor so i can compressor 8 tracks at once?
If i can use the aux send would i just set the levels all the way to "11" on my board and control the amount of dynamics on the compressor?
hmm.....
Thanks
Old 07-27-2004
Pro Tools User Pro Tools User is offline
Senior Member
Pro Tools User is a jewel in the roughPro Tools User is a jewel in the roughPro Tools User is a jewel in the rough
hmm.....
Thanks
dynamic processors are used on inserts and effects processors are used on aux sends. You probably wouldnt want to use the same type of compression on 8tracks anyway. As inserts you have more control and can give your tracks different character with less or more or no compression at all. Hopefully you catch my drift.
Good luck
Who ever Said this would be Easy!!
Sight Thru Sound Recording Studio
Old 07-28-2004
VU-1 VU-1 is offline
Newbie
VU-1 is on a distinguished road
I can think of a reason to use the same type of compression on "8" tracks:
A common mix "trick" is to send signal from all tracks of a drum kit to a stereo buss and strap a compressor across that buss. You would then compress this drums buss more than normal and then mix it back in underneath the original drum tracks. This will make the drums sound bigger and fuller. You could do this with gtr tracks, BGVs, etc... It's called parallel compression.
Also used in mastering sometimes...
O·T·R Mastering
Professional Audio Production for Life
Old 07-28-2004
robin watson robin watson is offline
Force of Nature
robin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond reputerobin watson has a reputation beyond repute
But the point being that you wouldn't use a compressor on an Aux, but rather an insert (at least that's always been my thinking). The parallel compression ex. you give would still be via insert...no?
I take note of your point though; I'll try this on the results of the up and coming band drum recording.
Old 07-28-2004
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
The other thing to watch out for is, if he is doing this on a computer, some programs don delay compensate the auxes. That would be quite a mess
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 07-28-2004
kylen kylen is offline
Force of Nature
kylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond repute
I'm using one on an aux right now - it can go on either side of a reverb depending on what sound you're looking for, for example.
Old 07-28-2004
Newbie
You are correct.
O·T·R Mastering
Old 07-29-2004
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
I think a few reasons why you always want to put dynamic processors on the inserts is because you want it to be usually pre-EQ and because we want to replace the channel with a new effect. With Auxes you are getting a wet and dry signal...with inserts you only get the effected version. So yeah, if you're wanting to compress multiple channels, bus them all to a grouped track and compress that one.
www.redlabaudio.com
Old 07-29-2004
paresh's Avatar
paresh paresh is offline
Dedicated Member
paresh is a jewel in the roughparesh is a jewel in the roughparesh is a jewel in the roughparesh is a jewel in the rough
when to use compression
Hi - I'm recording a meditation CD w music in the bkground. I want the spoken instructions to stand out but don't want to loose the music. Should I use compression? When - when I bounce tracks or in the final burn to CD? Thanks.
Paresh
Old 07-29-2004
Cloneboy Studio Cloneboy Studio is offline
Cloneboy Studio will become famous soon enough
Set the compressor to duck the background when the spoken word comes in.
