Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-22-2004
Arash Arash is offline
Newbie
Arash is on a distinguished road
Help starting up LM-4 Drummachine
Could someone please help me starting up the Lm-4?
I've looked in the help but I can't the get the "Open drum editor" option to get enabled.
Does one have to start a certain type of project to be able to use the drummachine?
I'd be glad if someone would write a step to step guide of how to get a quick start.
Thank you,
Arash
Old 07-22-2004
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
If I remember right, you can't open the drum editor until you actually record a little bit of MIDI. Set up your track, hit record, and hit a drum pad or two. Now stop it and you should be able to open up the drum track and construct your beats from there.
Good luck.
Old 07-22-2004
Easto's Avatar
Easto Easto is offline
Dedicated Member
Easto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud ofEasto has much to be proud of
There are different track "classes". You need to make the track you want a "drum" track. There are little Icons for Audio/Midi/Drum next to each track. When you click on them it should give you the option to chose the track class i.e. drum
Old 07-24-2004
Newbie
I have Cubase SX V 1.0.5.58, and I don't see any icons indicating Audio/Midi/Drums next to the tracks.
Do I start a 16-track Midi Sequencer or can I choose the 16-track surround mix? When I add the track, do I add a "MIDI Track"? Do I choose the LM-4 as that tracks input? What do I do after?
I hope you'll excuse all the questions....
Arash
Old 07-24-2004
Easto's Avatar
Dedicated Member
All you have to do is make sure that one of the tracks is a Midi track. Then in the inspector (for that track) associate a drum map with that track and you should be good to go.
Sorry but I'm going on memory but I believe you can go to one of the menus and chose "add track" and then when it asks you what kind chose "drum".
Old 07-24-2004
Newbie
Alright, I've managed to get the Drum Editor option available. How do I convert these drum "tabs" to sound?
