Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 07-20-2004
baerstev baerstev is offline
Newbie
baerstev is on a distinguished road
reference monitor problems
Does anyone have a recommendation for a reference monitor that is similar in its EQ response to most stereo systems, or that will give me a true sound? I bought a pair of reference monitors (Event TR8s), thinking it would be a huge improvement from the stereo system I was using to mix on. After hours and hours and hours! of tweaking my first three songs, I took them to other stereo systems and could not believe how much bass was in the mix on each song. Talk about frustrating! I have heard from people on here that you have to sort of learn how to adapt your mixing style to your speakers EQ response, and check things out on other systems. This makes sense to me to a point, but when I am going to have to burn a CD, and listen to it somewhere else and then make adjustments, burn another CD etc., it almost defeats the purpose of having a reference monitor. I turn down the bass in the mix, burn a CD, drive home to check it out on a couple other systems, and then it sounds tinny-add some mids, burn a CD, check it out, now its harsh etc.... hard to tell what is just right when I don't believe the monitors especially when its a matter of 1 or 2 db and this is real ineffecient-and I am feeling the pressure from my band to get the album done. Obviously with the speakers I bought, the bass response must not be very true or consistent. I listened to other bands' CDs on those speakers, and tried to make the frequency response sound just the same. Didn't work. Maybe I am just not in the right price range for monitors... spent about $400. I hate to spend more on them, but maybe I have no choice. Anyone have experience with TR8s? Suggestions for different monitors? Thanks for your time.
Old 07-20-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
It's more likely a room problem than an issue with the monitors.
If you end up with bass-heavy mixes when playing them on other systems, this suggests your listening position has a hole in the low-end response, causing you to boost your lows excessively.
Look at Ethan Winer's website for info on room treatment......
Old 07-20-2004
4-Man Takedown 4-Man Takedown is offline
Senior Member
4-Man Takedown has a little shameless behaviour in the past
Yeah, definately sounds like a room problem. Unfortunately it will take a lot of time to get used to your monitors and your room, but room treatments are generally super expensive, so you may have to deal with it. Try using some quality headphones every once in a while to reference your bass, I've done that with some success. Better than just guessing and testing all the time I guess.
What type of room you mixing in?
Old 07-21-2004
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb
Baer,
> I took them to other stereo systems and could not believe how much bass was in the mix <
This is very common, and as Blue Bear said the problem is surely your room. Even mid-level loudspeakers can give good results - look at the continued popularity of NS-10s! But even the finest speakers in the world are useless if your room has no bass traps and other acoustic treatment.
--Ethan
The acoustic treatment experts
Old 07-21-2004
Why 2K?
Lightbulb
4-Man,
> room treatments are generally super expensive <
It's all relative. When considered in the grand scheme of things, like the cost of decent microphones, loudspeakers, and other recording gear, bass traps and room treatment are not very expensive.
--Ethan
Old 07-21-2004
Jimmie's Avatar
Jimmie Jimmie is offline
Junior Member
Jimmie is on a distinguished road
It may not be the room here is what I learned from engineer's and what little experience I have ...
There are 2 paths sound travels in mixdown
1. The path to the mixdown machine
2. The acoustic path to your ears
There are so many factors as to why you mix on a good pair of monitors and the bass is outta control when you play the CD in your car, yet it sounds good when your mixing it down. In respect, who listen to there stereo system in a sound chambered room? not me, that is why NS10's are popular, they are crappy "flat" sounding monitors. Which with the 2 paths I mentioned give you the most realistic view as to what it will sound like from a cheap car stereo.
Check this site out ... it will give you an insite as to what is going on
http://www.johnvestman.com/studio_monitor_madness.htm
jr
have fun, it will be a never ending circle of confusion .. at least it still is for me
www.jamesrogersband.com
www.zucafe.com
Old 07-22-2004
Why 2K?
Lightbulb
Jimmie,
> Check this site out <
Other than the suggestion to use acoustic treatment, which is valid, I disagree with pretty much everything else in that article. Improve your sound with replacement power cords? Give me a break.
--Ethan
Old 07-22-2004
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
Originally Posted by Ethan Winer
Jimmie,
--Ethan
I'm with Ethan on this, except that I think getting a sub (or pair) would help.
If your mixes are sounding like reference CDs like you had mentioned, but are still ending up bottom heavy when comparing the same reference CDs on other systems then you aren't hearing the bottom correctly. You need to be able to hear down to 20Hz (and up to 20K) with the flattest frequency response possible on whatever monitoring system (and room) you are using if you want to make accurate mixes.
The purpose of a reference monitor is to (hopefully) create the flattest response and should therefore NOT represent a "standard stereo" system since this purposely adds character that varies from manufacturer.
Until you can afford a sub and room treatment, you may want to compare the bass response between your mixes and a reference on a pair of headphones, though this isn't the best way of fixing the problem.
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 07-22-2004
Jimmie's Avatar
Junior Member
The suggestion that it is the room is not a fair statement. I don't agree with everything in that article, but at least the article gives one an insite that there are many variables as to why we experience "STUDIO MONITOR MADNESS"
I agree with you on the cable issue too. But I look past that and to the point of what this guy is saying in his opinion.
it's all personal opinions.
www.zucafe.com
Old 07-22-2004
Old 07-22-2004
Jimmie's Avatar
Junior Member
I meant not just the room, room is an option but not the only one.
www.zucafe.com
  #12
Old 07-22-2004
Jimmie's Avatar
Junior Member
Don't we have more productive things to do than argue? haha Maybe go back to making music?
*just killing time dumping 1" recording to the harddrive"
www.zucafe.com
  #13
Old 07-22-2004
Jimmy -
You're right, it's not the room alone. A monitoring system IMHO is mainy a combination of the room, the speakers, and your ears. Even the same pair of speakers will sound completely different from room to room.
From the info I have, the Event TR8s go down to 35 Hz, so there is a piece of the puzzle that they are missing. A sub would definitely help there.
Keep in mind that you can't account for the things that you can't hear. Non-referenced "monitors" are going to add their character which will most likely hype the bottom and top in different ways. You really have to be intimate with your speakers, room, and any other issues that will skew your perception of what you are listening through in comparison to the "norm". It doesn't mean that you can't create a great recording under less than optimal conditions, you just need to know how to compensate or have the patience to play "sneaker monitoring" by checking on other systems.
Oh yeah, and be sure to use the best power cables that you can afford
Tom Volpicelli
MySpace:
  #14
Old 07-22-2004
doulos doulos is offline
Dedicated Member
doulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond reputedoulos has a reputation beyond repute
id rather hear accurately at 52 hrz then unaccurately at 20hrz just cause they say they can go down to 35 hrz doesnt mean that they are a flat responce interesting how even top monitors stick around 45hrz an up?
  #15
Old 08-30-2004
earworm's Avatar
earworm earworm is offline
it might be true...
earworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond repute
ok
now,
what's the difference between "reference" and "nearfield" monitors ?
nearfield= it are 'small' speakers that are positioned close to your ears
reference= ehm, they got a flat response so you can try to compare a commercial cd with your sound ?
how wrong am i ?
thanx
earworm
...listen...
