linking different adat models
Can i sync different alesis adat models, like the blackface and a xt model?
Yes - you should be able to - as long as the sample rates are the same........
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
Just connect that ADAT 9-pin sync OUT on the first one, to the ADAT 9-pin sync IN on the second one. If you have more machines, rinse and repeat. Should be no problem at all.
Good Luck.
Eric Practice Your Mixing Skills! Mix Our Tracks in Your DAW! www.Raw-Tracks.com Online Mixing Forum |
All ADATs will sync together with the serial sync cables properly attached. Tape-based ADATs will sync with the hard-disk HD24 as well. The blackfaces wind/rewind time is much, much slower than an XT or XT20, if sync'd to a newer machine, give it time to sync and lock. Also, if you're using mixed ADATs sync'd together, remember to not switch the tapes from one unit to another. Use the same tape in the same machine each time. Remember that blackface ADATs record in inverted phase on the tape... it's corrected on playback. XT and XT20's don't do this.
People slam them all the time, but I think ADATs are great! |
Aaaaaaaaaaaaaaaaaaaaaaamen |
