Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-13-2004
utsman utsman is offline
Senior Member
utsman will become famous soon enoughutsman will become famous soon enough
Saving only the goods
Is there a way to only save the audios that you actually want. Let me explain. When I am recording and say do a guitar bit that isn't quite right,I rub it out and do it again. But this bit actually gets saved in the folder. I end up with shit loads of audios that I don't want and a huge folder. Then I don't know which is which and can't delete them for fear of being a tool again. I like to record a lot and pull out the best bits.
Old 07-13-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
When you're done with your project (or you're sure you want to purge files) - go to the Pool window and choose "Remove unused media" - this will delete any media files not used in the current project.
Mind you, if you put multiple project in a single folder (bad idea anyways), this will not work for you....
Old 07-13-2004
EleKtriKaz EleKtriKaz is offline
Home (w)Rec'r
EleKtriKaz will become famous soon enoughEleKtriKaz will become famous soon enough
Like Blue Bear said, make sure you keep your projects in separate folders that are well labeled. It really sucks to accidentally delete something that you didn't mean to delete. REALLY sucks.
Old 07-14-2004
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Removing unused files doesn't actually remove the files though. It just moves them. Removes them from the actual pool to the trash. If you want them to stop taking up space, you also have to empoty the trash from within Cubase. (same menu that has remove unused media option)
