Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-12-2004
skaman skaman is offline
Junior Member
skaman is just really niceskaman is just really niceskaman is just really niceskaman is just really niceskaman is just really nice
Sample rate
how do i set the recording sample rate in cubase? i want to set it to 32 bit, 48 kHz but i just dont know how to do it!
Old 07-12-2004
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
you can do it in "project setup" which is under the second or third menu column...I can't remember which one. Anyhow, go to project setup and it will give your samplerate options there.
Good luck!
Old 07-13-2004
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
It is under the "Project" menu like Bass Master was saying above. Out of curiosity, why do you want to record in 32 bit float?
Old 07-13-2004
playit's Avatar
playit playit is offline
Junior Member
playit is an unknown quantity at this point
Sometimes if you've set it up this way, you have to use your sound card's properties to set the sample rate, because Cubase will pull from there.
One such sound card is the Delta 1010LT. You can also change these settings though, to give Cubase control. For more information read the help and your sound card's manual.
Old 07-13-2004
Junior Member
thanks everyone
i found got damn sample rate! thanks to you guys!
