Should I cut out the Mackie?
I have been using the MOTU 828mkII with DP4 to record songs for the last 8+ months. Just recently I submitted a song in the MP3 Mixing Clinic called "One Man Band, Please Listen..." I got a comment that my song has a muffled sound to it. Now that I listen to it, I realize that it does sound a bit muffled. I am currently running a 16 channel snake into a mackie 16 channel mixer, then out from there into the MOTU.
My question: Should I cut the Mackie out the the chain all together? Will doing that take away the "muffled" sound? Please check out the song, and help if you can. Thanx,
Tustin |
Best practices dictates "minimal signal chain ALWAYS" for optimal results.
If it doesn't need to be there, take it out completely..........
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
I believe that your MOTU box only has two mic inputs which is a serious consideration.
I would keep the mackie. I am not going to say that Mackies are as good as other more expensive things on the market, but they are OK. Hell, I have done major lable work on an old mackie in the past. I would also keep the mackie for mixing instead of mixing inside of DP4. The sound of your tracks summing in the Mackie will be better than the sound of summing in the computer. I did not hear the track you posted, but if your mix is muffled it may just need some mastering, or more likely not mixed right. A mackie mixer will not muffle a track to the point where you would notice it on an MP3
Ronan Chris Murphy Ronan's Recording Show My "TV Show" about recording. + Home Recording Bootcamp teaching other guys how to get in trouble |
Thank you for the feedback. My MOTU has 8 1/4 inch inputs.
Tustin |
What's the point of a DAW if you're not going to mix inside it? Automation, plug-ins, etc make it too tempting. I suppose you could still automate your individual tracks and put plugins on same then route from your converters to the mixer. I could do this too, but I'd need to reroute everything
The paradigm for my setup: All signals thru Mackie 32/8-bus > out the inserts into 2 Delta 1010's > into Sonar >automated with StudioMix Control surface, is basically a poor man's version of a friend's Pro-tools setup as he has a Neotek board (and a zillion top of the line pres) going into the PT converters into the software and automated with a Pro-Control. He does a lot of Label work, and I know my signal chain is not close to his but...I still think shortcomings of my mixes lie with me.
"Don't taze me, bro. Don't eeeeyyaaahhhh...." |
I tend to think there are other factors causing your sound to be "muffled". Technique being one of them, microphones being another. As someone mentioned previously, you probably need the Mackie for extra mic preamps. That's OK. The Mackie is not that bad. I think you should try to evaluate your situation a little deeper. Is there a certain aspect of your production that sounds muffled? Is it just the vocal, for instance, or is it the entire mix. It could be a build up of mud in the low frequencies causing the muffled feel.
Eric Practice Your Mixing Skills! Mix Our Tracks in Your DAW! www.Raw-Tracks.com Online Mixing Forum |
#12
I am sure that there are guys on this site that sum in the box and think its great, and that is totally cool for them, but if you ask guys with a lot of experience with analog and digital summing it is "almost" unanimous that analog is superior
#13
You could still do all of your automation, etc. on the computer, but use the mixer for the actually summing and bounce to a stereo track. I'm going to try it if I can figure out how to do it. My main complaint with my mixes is that they don't seem to have depth and, for lack of a better description, air. In a really good mix, I can hear the empty spaces, and I can't hear them in mine.
#14
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini (formerly S.P. Technology |
#15
One thing that people do not realize is that when you change the level of a digital audio track only .1dB the sound degrades. If you don't believe me try it with a finished mix. If you have really good monitors you should hear the difference. Also I just love the feel of using real faders.
#16
Just give me a decent analog console and I'm fine. Fancy preamps aren't really my thing. |
#17
#18
I second that?????????
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F. |
#19
Mike |
#20
Depending on the Mackie, there my not be dedicated tape returns, in which case it would be going through the pre-amps again -not that that is necessarily the issue here.
#21
The mackie that I use is the 1604VLZ. I have had it for a while. Maybe someone could tell me how to route it to get best sound quality?
Thanx,
Tustin |
