Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 07-09-2004
JDIR JDIR is offline
Newbie
JDIR is on a distinguished road
Help ! no audio with SX2 !
Hello all,
Please help if you can, I am new to Cubase and all that goes with it, so all help is really appreciated. My problem is audio!
I am running SX2 on my laptop (windows XP) using my old Korg 01WFD as control, thru an M Audio Quattro and MU80 sound module. I am getting the hang of the midi aspect and can record and get sound out , but alas I am not able to get audio in or out. This is probably a basic problem for most of you but it is driving me potty. Please help, and thanks for your time.
JR
Old 07-09-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
I suggest yuou have a look at the manual -- it clearly describes the input and output routing you need to set-up for audio.
Old 07-09-2004
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
Yep, the "Getting Started" manual that comes with the programs walks you through getting your audio recording set up. It's really easy to follow.
Good luck.
Old 08-01-2004
Newbie
Thanks guys, got it sorted. My problems was preamps, all sorted now. Now the next problem, really bad glitches with audi playback. I am getting audio in, guitars & vocals, but when played back it glitches really badly. The glitches appear to happen at the same time as my laptop indicates activity with the flashing LED light. I have no trouble with the midi tracks, its only when I playback audio, any ideas ? and thanks.
Old 08-01-2004
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
What's a glitch?
Old 08-01-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
Drop Outs and skips can be attributed to hard disk throughput. Chances are your laptop has a 5400RPM drive (kinda slow for multitracking ... not to mention it's only ONE drive ... thats a lot of work for the drive to run the OS, programs and stream the audio data all at the same time). You may be able to get better results by increasing the sample buffers a bit and make sure that no unnecessary programs are running in the background and defrag regularly.
Worst case ... you may have issues with the chipset used for the USB controller in your laptop or some IRQ's not willing to share very well.
~It all works out in the end~
Old 08-01-2004
crankz1's Avatar
A couple of helpful links .....
MusicXP - tweaking for DAW work.
Black Viper - trim some fat off XP.
