Old 07-08-2004
notbradsohner notbradsohner is offline
Compression Addict
notbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond reputenotbradsohner has a reputation beyond repute
surround mixing
besides a set of surround monitors, how would i mix master something in surround. (5.1) any suggestions for software, and do i need a surround amp, or powered surround monitors?
i want to mix stuff i already have on my comp
Old 07-08-2004
Stealthtech's Avatar
Stealthtech Stealthtech is offline
LOGIC ABUSER
Stealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond reputeStealthtech has a reputation beyond repute
Logic Audio 5.8 and up will do it
Logic Audio Abuser
Old 07-08-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
You'll need the software (Logic, WaveLab 5, etc.), the hardware (at least 6 outputs) 5 matching monitors with matching amps & a subwoofer properly calibrated to the rest of the monitors, and a properly tuned room.
For starters...
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 07-08-2004
Compression Addict
so each monitor is powered seperatley?
Old 07-08-2004
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Yeah they would have to be, they each have discrete signals.
I'm putting in a 2.1 system (LR plus mono rear & sub) and then developing a tool to translate to 5.1, but that's definitely less than desirable. However in my tiny studio I seriously doubt I can independently image 5 channels, so that's the route I went. It will be fun to play with. For the rear speaker I went with a full range Fostex driver in a little cube cabinet rather than an all-out two-way monitor, which saved a bit.
In my greatest eBay score ever I got a Miles Tech 6 channel power amp for less than $300. I'd never heard of them before, but I nearly wet my pants when I opened the case and saw the giant caps and transformer. It retails for $1100
Old 07-09-2004
Compression Addict
what if i can get my hands on 5 powered monitors, all with the amps built in?
Old 07-09-2004
Faithful Departed
That works.
