Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 07-07-2004
adam_in_audio adam_in_audio is offline
Senior Member
adam_in_audio is on a distinguished road
question on recording Bass guitar with a Direct Box
hi y'all!
I have actually been recording for a while but everytime I've recorded bass, I've mike'd my amp using a Sennheiser 421. I am now transplanted to an apartment with pretty thin walls, so I'd like to get some advice on how to correctly direct record my bass guitar. I probably should know this by now and I feel like an idiot asking, but that's how it goes :P Anyway, my bass has active electronics and I would like to run directly into my soundcard console bypassing the amp. Is there any techniques y'all use or are there good DI boxes you can recommend, I've heard good things about the Sansamp Tech21.
any help would be GREATLY appreciated!
Adam
Old 07-07-2004
DaveO's Avatar
DaveO DaveO is offline
Force of Nature
DaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond reputeDaveO has a reputation beyond repute
Thumbs up Sansamp Bass Driver!
If you do a search on the Sansamp you'll get back loads of posts praising it. To be fair, you'll also get back some saying it's not what that user wanted, but from what I've seen the reviews have been overwhelmingly positive.
I've been using one for almost two years and love the results I get with it. Before that I was using my ART Tube MP, mostly out of necessity since it was all I had. However, it did a pretty good job. My actual signal chain is a combination of both beacuse I use my ART to provide phantom power to my SABDDI. This (bass -> SABDDI -> ART -> soundcard) works very well also.
I also have a guitar POD (2.3) which I tried on bass. It was OK, but I never found a combination of settings that I really liked. I came closest with the Tube Preamp and no cabinet but that always seemed noisy to me. So I went back to the ART and eventually got the SABDDI.
Does your amp have a direct out? If so, you may as well try that first since it's free.
____________________________________________
Dave O.
Old 07-07-2004
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
You might want to look into the Countryman active DI box, too.
The Bass SansAmp is pretty good and it's more than just a DI box.
If you want to go even further, look at the Line 6 Bass Pod or it's cheaper cousin, the Behringer Bass V-Amp Pro. I have the latter and it's an excellent recording tool.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 07-07-2004
dirtythermos dirtythermos is offline
Dedicated Member
dirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond reputedirtythermos has a reputation beyond repute
Compression will help a lot, too.
Old 07-07-2004
Senior Member
thanks!
cool! thanks for the advice, I'll look into all these options!
Old 07-08-2004
Adam P Adam P is offline
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
Since you have active electronics, you should be able to plug your bass directly into your recording interface. It won't give you a huge variety of tone options the way an active DI box would, but it'll do the trick. Its worked for me with my Active Jazz and Layla interface.
Old 07-08-2004
pennylink pennylink is offline
Dedicated Member
pennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond reputepennylink has a reputation beyond repute
For the most part I just go direct into the Hi-Z input of my Aardvark Q10 soundcard, with what I think are acceptable results. I guess to some extent it depends on what kind of bass you're using (I use a Peavey T-40).
I've also used a Johnson J-Station from time to time, which has some bass presets. The J-Station has been discontinued, but you can pick up a used one on eBay for around $100. The benefit is that it also has very good clean guitar sounds in it, and a pretty decent Rectifier sound.
At some point, and when budget allows, I think I'll get the SansAmp though.
There's also the Line 6 Bass POD amp modeller, but I think you'll do better with the SansAmp for less money.
My recap:
Most economical option: direct to soundcard
Fairly inexpensive: Johnson J-Station (around $100 used, with additional guitar sounds thrown in)
Least economical: Tech 21 SansAmp Bass Driver ($140 used, $190 new, but probably has the best sounds)
Old 07-08-2004
DJL DJL is offline
Banned
DJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to all
If you guys haven't heard the Ampeg SVPCL preamp yet... you might want to give it a listen.
Some of the other preamps I have are the Avalon U5, SansAmp, Countryman, and yes I even have a ART Tube MP Studio V3... lol... and a bunch of others. The two I seem to use the most are the U5 and SVPCL. Just to give you an idea of the sound I like... I play a Rick 4003 and Fender American P bass and J bass. I play through Ampeg SVT amps and like "adam in audio" I too like miking my amp with a MD421.
Old 07-08-2004
Imaduck's Avatar
Imaduck Imaduck is offline
Senior Member
Imaduck is on a distinguished road
If you go from your Sans into a clean setting on a JStation, it sounds pretty good, and the JStation will give you a good amount of additional volume/tonal controls.
