Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 07-05-2004
Jayme's Avatar
Jayme Jayme is offline
Senior Member
Jayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond reputeJayme has a reputation beyond repute
Exclamation Eh? why do my hotrods keep breaking?
Why do they go to pieces?? (the thin strands keep snapping off one by one)
Is it the way i'm playing? are you ment to rimshot or are you ment to flick with them?
Please give a hand!
Jayme
Old 07-05-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
Yeah they don't live to long with heavy playing or rim shots. They are more for playing with finesse. You really need to have a handle on dymanics to make um last very long.
~It all works out in the end~
Old 07-05-2004
mikeh mikeh is offline
2.5K Gold Member
mikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond reputemikeh has a reputation beyond repute
I've always considered Hot Rods (or Cool Rods, etc. etc.) to be a tool much like brushes, used for a certain effect. I'f you play hard with them (in particular hitting rimshots) they won't last long - but that is not what they are designed to be used for.
As crankz1 indicates, they should be used with more "finesse". Many drummers turn to dowels simply because they can't control the volume of the drums - but learning to play softer (maybe even use a lighter stick - like 7A's - for certain applications) is a needed skill.
Once a drummer has better skill in dynamics, then the Hot Rods (or brushes, etc) can be used properly as an effect, rather than simply something to keep the volume down.
Old 07-06-2004
Jayme's Avatar
Senior Member
Question
Originally Posted by mikeh
- like 7A's -
I use 5 b, but i don't realy understand how the sizing of the sticks work, What order do the go in?
Old 07-06-2004
2.5K Gold Member
As a general rule:
The higher the number series, the lighter the stick - and the higher the alpha, the thicker the stick.
So - a 5B is slightly thicker than a 5A but the 5 series is heavier than then 7 series, but lighter than the 2 series.
So something like a 2B is a very thick/heavy stick (for serious rock & roll bashing) and a 7A is a very thin light stick (often good for jazz). Naturally with all the makes and models it tends to get confusing - however mose sticks are simply a variation on the 2's, 5's or 7's (a gram more weight or a centimeter different in length, ec)
When I sold drums (or when I taught) I recommend a 5A or a 5B which are rather standard sizes.
