Old 06-26-2004
iceman79's Avatar
iceman79 iceman79 is offline
Newbie
iceman79 is on a distinguished road
Problem w/MR-8
I got my MR-8 2 weeks ago and so far I like it. The only problem is that when I use the "Powerful" button it causes the volume to go up and down, almost like tape flutter. Is this a well known problem? Is there a fix for it?
any info is greatly appreciated.
Old 06-26-2004
radiorickm's Avatar
radiorickm radiorickm is offline
Senior Member
radiorickm is on a distinguished road
powerful
the powerful and natural buttons are what they call mastering effects. the powerful button will increase the volume considerably, especially in the bass range.
i take it from your post thought, that it causes the levels to "change back and forth". that isn't normal.
good luck
Old 06-26-2004
Happydude22 Happydude22 is offline
Newbie
Happydude22 is on a distinguished road
I just got an mr8 too, & am just discovering the same kind of flutter on my tracks. I used the natural & bright buttons. The flutter wasn't there while doing mr8 playback prior to bouncing.
Old 06-26-2004
iceman79's Avatar
Newbie
Ok guys, after playing around a bit with the old MR-8 I found that the levels stay constant and the flutter ges away when you bring the faders down (including the master). Now it's perfect!
Old 06-27-2004
Newbie
Thanks for the info. How far should you bring them down so as not to reduce volume, or do the faders have anything to do with the recorded volume anyway?
Old 06-28-2004
dave in toledo's Avatar
dave in toledo dave in toledo is offline
Force of Nature
dave in toledo is on a distinguished road
mr8
i feel those effecst are a poor use of a preset eq, they really dont sound very good, you are better off not using them and trying to get a good mix is hard enough....
best bet is moving files to the computer for mixing, but if you dont, i think you will get a better recording without those presets ;my 2 cents....
been around awhile
Old 06-28-2004
pjh6467 pjh6467 is offline
Senior Member
pjh6467 is on a distinguished road
Cool faders/flutter
The faders for the tracks are not your recorded levels but used for playback and mixing to tape or into your pc(via soundcard) The master fader takes all your tracks recorded levels and combines them left and right. This is the overall level of tracks combined. You want your master level to be just under or around 0db with left and right meters staying even with one another. So if you use the powerful setting,start your master fader at 0 and work your meter up to 0db. Hopefully the flutter won't occur before you reach that level. But like Dave said if your takes are eq'd well and and at good levels you shouldn't need those presets at mixing time. The MR8 can do a lot of things,but no eq. Good luck Pj
Old 06-29-2004
kdgospel kdgospel is offline
Dedicated Member
kdgospel is on a distinguished road
I think the "flutter" you are hearing using the mastering presets is because these presets are using compression. If your tracks are hot already there is going to be a lot of "flutter" in volume especially on the powerful preset. Like someone else said these presets are certainly not high quality. You would do better to transfer the tracks to pc and use some kind of compression there. I like endorphin myself. www.digitalfishphones.com
Old 06-29-2004
Newbie
Thanks for the tip, but it's not available anymore per the website - it said no more freeware. Any others to suggest?
Old 06-30-2004
Dedicated Member
You can still download it for free. I just downloaded it here at work. It is a VST plugin so you have to have something that accepts VST plugs.
Old 07-01-2004
Force of Nature
effects
do a search for vst and direct x effects,
i have had some problems with endorphin, after checking with some of the more advanced users, i have found the classic master limiter, and the classic compressor sound much better then endorphin....
many links available at audiominds.com
including endorphin and the two i mentioned
been around awhile
  #12
Old 07-01-2004
Dedicated Member
Thanks for this information. I have never used any of the Classic plugs.
  #13
Old 07-01-2004
Newbie
I've got them them both, but they're all dll files. Do you use them in conjunction with some other program?
  #14
Old 07-02-2004
Dedicated Member
VST plugins have to be used in conjunction with other programs that accept them. N-track will accept them. To get them to work with N-track you just unzip them to the "plugins" or "VST" folder (can't remember which one?). Then when you open N-track and effects they will be there.
If you do not have software that accepts VST plugins they are worthless.
  #15
Old 07-02-2004
Newbie
what types of software? suggestions?
  #16
Old 07-02-2004
Reggaesoldier's Avatar
Reggaesoldier Reggaesoldier is offline
Dedicated Member
Reggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond reputeReggaesoldier has a reputation beyond repute
I agree the mastering effects are not even worth fussin' with. Go with outboard gear or plugins.
Good luck!
  #17
Old 07-03-2004
Newbie
Right on, Reggae!
  #18
Old 07-06-2004
Dedicated Member
N-track or other multi-tracking software that accepts VST plugins.
