I posted a similar question before, but got no response. Mayber if I re-word it...
Can anyone give me a reason why a compressor might lack a "Gain Control". (also called makeup gain or output gain...) When one of my comps (my Symetrix 501) compresses, it lowers the gain by x db, and there's no way of making it up to unity... This is unlike my RNC and DBX comps... and it sucks for comparing processed vs. unprocessed signal, as the apparent volumes are so different. Is there ANY reason a respectable manufacturer like Symetrix would do this?? Hell even the Alesis 3630 has a Gain control. (I think... )Is it just assumed that I'll make up the gain by jacking up a fader?? That doesn't seem right....
If Bruce Springsteen is the Boss.... I quit..... Oh, and PMC#11 8th place winner!! ![]() Learn the scary truth about "The Religion Of Peace"... click here |
you prolly got no response because no one here has a similar experience because it seems to make no sense...you sure the output gain knob isn't under a more esoteric label?
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage |
The comp has 2 channels... Each channel has the following 4 controls: Attack, Release, Ratio, Threshold That's all... Oh, and an In/Out button.... and a button to cycle through it's other functions: Comp/Ducker/Gate/Expander The model is Symetrix 522...
Oh, and Symetrix has no doc on their website... The unit has been discontinued... Google show nada...
My 525 has not attack or release controls, but plenty of output gain! Are you running it as in insert to your board, and if so, can't you just take up the track's gain slider? Most boards have an input gain knob that is pre-insert, and a gain knob or slider that is post-insert.
But, I'm running it not quite as an insert... I'm using it between a Symetrix sx202 and a line level channel on a Behringer board (For monitoring/routing) into a Delta 44. I can slide up that channel's fader, but it still doesn't let me compare in/out compressor settings, w/o having to make volume changes at the board. (As you know, almost any increase in volume is percieved as "better"... :-) This was, at one time, a pricey, decent compressor. I just figured that they might have had a reason why they ommitted such a standard control. Even Alesis has a Gain knob. Shheeessshhh!! Thanks though....
Yeah, that was my point. Your 522 has no gain knob, my 525 has no attack or release controls. I guess Symetrix didn't want to confuse the issue by putting too many controls on there.
In my experience, the Symetrix compression is easy to hear. Just try a couple recording passes, make changes, note the settings for each pass, then listen back and pick the one that sounds best. I use the symetrix on drums, so it's pretty hard for me to tell what it's doing to the sound while I'm adjusting it and playing anyway, but I give myself a few different options on playback, and then pick the one I like best. Sorry I don't have a better answer for you! |
No problem... I just think it's like selling a car w/o air conditioning, or a transmission... (bad analogy ;-)
No output gain on a compressor is unheard of. i would just sell it and get one that has it.
Well... just out of curiousity.... I shot an email to Symetrix today....
15 minutes later, I had a response (on a VERY unsupported product!!!! Imagine if it were current... I guess they would drive out to my house!!!) THESE GUYS ROCK IN THE SUPPORT DEPARTMENT!!!!! Quote:
