Yamaha MG 12/4 routing
Okay, I know there's a way to do this or I wouldn't have got it, I've had it explained to me but waited to long to put it into practice. I'd like to record 8 tracks simultaneously. I'm using a delta 10/10, a DMP3 and a Yamaha MG 12/4. I know it deals with using the auxes and panning hard L&R but I'm a bit confused. I've also heard of tapping the inserts as direct outs but this was frowned on by others, who's tried this?
option 1:
The easy way to do it is to buy 8 1/4 TRS to mono 1/4 cable and come out of your inserts. You would put the stereo 1/4 TRS in the insert and the mono end into your recorder. Its a mono 1/4 to stereo 1/4 cable. (radio shack keeps them in stock. If you have to you can also use a stereo 1/4 cable and get a stereo to mono adaptor from radio shack. Option 3: Buy a patch-bay and tap the inserts with a 1/4 TRS to dual 1/4 mono and into the patch-bay and then tap the patch-bay with a 1/4 to your recorder. You'll have to set the patch-bay so that the input signal is routed out to outs so you can return to your mixer and also send your recorder. I thing its called half nomalized I could be wrong on that one. Option 2: Channel 1 paned hard left Channel 2 panned hard right Channel 3 buss out hard right Channel 4 buss out hard left Channel 5 Aux 1 send out (make sure no other channels are on the aux mix and also aux send must be pre fader because channel 5 fader will need to be down) Channel 6 Aux 2 send out (make sure no other channels are on the aux mix and also aux send must be pre fader because channel 6 fader will need to be down) I don't have one of these boards I'm going off of a pic from the web, but I think I'm right. The buss send might have another name. Before I got my Soundcraft M8 with direct outs I used my inserts. |
I have the Yammie 12/4, and here's how I would get 6 channels out of it:
Tracks 1-4 are all mono -- use the inserts. Tracks 5/6, 7/8 are stereo. Send them both to the "Group Outs" (push the '1-2' button below the 'PFL' button). Pan one L, and one R, then run your last two cables from "Group Outs" on the back of the mixer. And the last 2 channels obviously come from the DMP3. Hope this helps! ![]() |
Thanks for that one! I have own a Yamaha 12/4 unit & I've found it to be a great little mixer for the dough. Pretty darn clean sounding and it also has a lot of useful features. Agreed?
Sweeeeeeeeet
Thanks guys!
so if i have an RCA to quarter inch snake, could i plug it into the insert i/o plugs on my yamaha mg 16/4, and then plug the rcas into my delta 1010lt?
(dont have it yet...getting one soon though i think) |
Routing to monitor effects
The manual was not much help and i'm still new to this. I want to be able to run my guitarists signal thru his effects box, so he can hear his effects while he's recording, but I want only to record the dry signal and add effects while mixing.
I'm an idiot
never mind, I figured it out, Duh!
Well I thought i did, but then I didn't but then I did again. Actually Mosaic figured it out about the same time I did it by accident
.I'm never eating spaghetti again ![]() |
