Old 06-18-2004
guitarhunny's Avatar
guitarhunny guitarhunny is offline
Senior Member
guitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond reputeguitarhunny has a reputation beyond repute
More volume on a mixed song for CD?
I am using HomeStudioXL. Does anyone know if there is a way to bring the final mixed sound up to a more CD standard level?
Old 06-18-2004
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Generally you would use a compressor and/or limiter to achieve this.
I am assuming that the tracks were recorded at decent levels to begin with.
Old 06-18-2004
Senior Member
I record digitally with an MR8 then, I transfer via USB to PC for mixing on cakewalk. I am recording at the highest level possible without clipping. I probably am not using the compressor right. Is the cakewalk compressor ok, or will it muddy up my music? I want to keep the emotion in my music and I've heard that compressing loses some of it.
Am I fighting a losing battle? Should I just take what I can do and get over it? Please check out my website for a sound clip. Any input would be amazing. I can't tell if I really suck at this mixing stuff or if I am being overly picky and nieve about sound quality. How much does CD level matter?
www.ruthsharpmusic.com
The clips on this site are a little older, some of my new stuff sounds a little better due to some jimmying of the effects on the vocals.
Old 06-18-2004
Senior Member
I'm clueless and I know
Ok, I know that I am very stupid when it comes to this stuff. Could someone explain the function of "Trim". I have been playing with it to bring the level of recording up. Is that what it is for? I have to play with it some more to find an appropriate level where clipping does not take place. Does this make any sense?
Old 06-18-2004
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Thumbs up
Alert!!! Lady on the board.... behave, boys...
Let me tell you something... for "homy recordist", you realy did one heluva great job on your songs!!!
Anyway, IMHO you need to pay attention on your acoustic guitar sound. Tought it's wide, it rather goes thin on the mix. Was it mic'd, or pick'd up? The mixing level is fairly acceptable, it's about the time to bring it to mastering stage. Do you have any wave editor (CoolEdit, Soundforge, Wavelab, etc?) ? If so, then you can use it to do your own "mastering" job. Like dachay mentioned, you can use compressor/limiter to make up the gain. Can you tell us what plugins do you have? Your recording gears maybe?
Jaymz
Keep Rockin' and Rollin'...
Old 06-18-2004
Senior Member
Thanks for the response! Any feedback is good feedback especially when it is good.
My knowledge on the recording end ends about where I am. I know nothing about plugins and nothing about mastering. My guitar is plugged into my Fostex MR-8 not miced so I lose some of the realness in my playing. I am very low on cash flow so I can only go very slow (which is annoying) with the purchase of new and better ways of doing things.
What would be some recommendations for mastering stuff? I don't even know where to start.
Old 06-18-2004
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
Trim is generally the first volume control, on a preamp, or placed before the rest of a mixer channel's controls, used to get the incoming signal into the correct general level up front. Sometimes it's just called 'gain'.
For your master levels in Cake, it won't be much different than bringing up you mixes with the track volume control, assuming everything is in the ballpark to begin with.
On the mix, how about a bit of mild compression on the vocal and guitar tracks, and bring the guitar up some. (Sounds like it's just DI?) You can also try some compression and limiting on the mix too if you want to get the level up, but you might want to go easy on it. Most of the pop stuff we're comparing to is smashed to sh*t for the sake of volume -and sound like it.
Might be good to not try to go there for nice acoustic songs like these.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 06-19-2004
James Argo's Avatar
Fancy Rock N' Roll
Lightbulb
Well, plugins is processor/effects in software shape. It's an add on. You can use plugin as an effect in your audio track. Just insert them on the given field on track view.
Okay, it's a bit tough, but absolutely doable with experience. Don't worry, if you realy pay attention on how you set them propherly, then you may get better sound with pickup. First is to know your guitar's character. Listening to your song, the guitar has typicaly "screeech" sound when recorded. Try struming right in front of the sound hole rather than closer to the bridge. If you have an EQ, then cut -3db ~ -6db around 10kHz. Once again, it takes experience to obtain best result. If you don't have an EQ, then make sure you record it as loud and clean as possible (w/o getting clipped). We can play with EQ on mixing stage later.
Do you think we aren't ? That's why we're here...
Go:
http://www.directxfiles.com/plugins.htm
There's bunch of free plugins for you to download. Usualy you'll need compressor, gate, EQ, chorus, and reverb. Once you downloaded 'em, give 'em a try. Play with them until you know which one you need. We're here to help if you have any questions...
Jaymz
Old 06-19-2004
Senior Member
Thanks sooooo much. It's good to know people are out there willing to help me out.
Old 06-19-2004
dachay2tnr's Avatar
One Hit Wonder
GH:
Check your private messages.
And, no, it's not what you think, you reprobates.
Old 06-20-2004
Be Loveless's Avatar
Be Loveless Be Loveless is offline
Dedicated Member
Be Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud ofBe Loveless has much to be proud of
are you sure that you you really need it to be louder? If your trying to get it to consumer CD levels I would abort your mission immediately and really think about whether it might just be "loud" enough already. Don't become a compression abuser, it's a filthy addictive habbit.
The BLUE HUMOURS
  #12
Old 06-21-2004
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
A likely story........ I still maintain it's Moskus in a dress winding you all up....
Q.
<insert something witty here>
  #13
Old 06-21-2004
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
HEY! Where did you see that picture?`!?!?
Two wrongs don't make a right, but two Wrights once made an airplane...
  #14
Old 06-21-2004
dachay2tnr's Avatar
One Hit Wonder
Given my luck of late, I might find Moskus in a dress to be quite alluring.
But I'm really holding out for acidrock in bra and panties.
  #15
Old 06-21-2004
Senior Member
I really just want the levels to match up. I know I can be very picky and quite a perfectionist but When I put the songs on a CD and listen to them the volume levels just seem really low and I want to be able to distribute my CD and have it be something that people will actually listen to. I'm probably just being really picky!
  #16
Old 06-21-2004
James Argo's Avatar
Fancy Rock N' Roll
Wink
Pardon the homeboys here, mam... It's okay to be picky. We're all being one at a time, are'nt we * ?
Anyway, FYI, make up the level to match regular "CD level" is alot more simple done using audio editor, not Cakewalk. Cakewalk is not the best audio editor so far. It will do the sequencing, multitracking, mixing, etc. But to edit the result you'll need audio editor like Wavelab, Adobe Audition, Soundforge, etc. However, -although realy time consuming- you can do it in Cakewalk with experience. If you followed link I posted above, you'll find some free DirectX plugin like Richie's Compressor 1.0. It's not the best one, but it's free and you can use it to learn how to obtain what you wanted. Once you've done mixing your tracks, open new project, import the wave result, and insert this directX in the track. Tweak here and there. Learn what exactly those buttons do. If you have any questions, post here, and many probably will jump to help you...
Jaymz
*...imagine acidrock with his bra and panties
  #17
Old 06-21-2004
Senior Member
James Argo
I did go to that sight and am going to try a few of the plugins. I am also going to check into some of those other programs. It seems like I have been working on my music forever and am getting anxious to go out and perform with something to distribute. I know that there is great help here and appreciate it tremendously. I will be around this site probably more than people will want me but as long as people are willing to help the picky and slightly insane I'll be here. Thanks
  #18
Old 06-21-2004
Qwerty's Avatar
1K Silver Member
If it's really important to you, get it professionally mastered.
If not, grab something like iZotope's Ozone which will allow you to do fairly clean home-mastering without breaking the bank.
www.izotope.com
Ciao,
Q.
  #19
Old 06-22-2004
moskus's Avatar
Or if you have the cash, try the WaveHammer by Sonic Foundry (or now: Sony). It does the job, and does it well.
The only sad thing is that you need to buy Sound Forge to get it...
