Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 06-15-2004
lennart lennart is offline
Newbie
lennart is on a distinguished road
Well, TEAC owms TASCAM, and this is about an A3340S
Hello folks,
Right, so I bought a TEAC A3340S for about the equivalent of 200 of your A-merican dollars. I have some really old tapes that shed very reliably, and keep leaving muck on the heads. The deck seems very tempremental - I had it fixed up when I first got it because tracks two and four didn't record, and after that everything worked fine, but now only track one records reliably, and the other three are pretty lo-fi. My questions:
Does tape gunk affect recording levels to a very great degree?
If the problem isn't tape shed, but signal path, is the TEAC A3340S a machine worth putting a lot of work into, or just worth throwing at that idiot who decided to make a live action Garfield film?
Should I buy some new tapes or just bake the ones I have, which are mostly from the mid 80's, and mostly BASF--?
There's a TEAC 4-track DBX unit at my local dodgy second hand shop for about 130 of your A-merican dollars - how eager should I be to get that?
Should The erase head be expected to reliably remove all traces of previously recorded material? Mine leaves audible, but not distinct remnants.
Thank you for your help gentlemen.
Old 06-15-2004
The Ghost of FM's Avatar
The Ghost of FM The Ghost of FM is offline
French Mofo
The Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond reputeThe Ghost of FM has a reputation beyond repute
This FAQ should answer all your questions.
Please read it.
http://www.vaporpark.com/invboard/in...ST&f=12&t=310&
Cheers!
Old 06-16-2004
Revmuddy's Avatar
Revmuddy Revmuddy is offline
Senior Member
Revmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these partsRevmuddy is infamous around these parts
Originally Posted by lennart
Hello folks,
Does tape gunk affect recording levels to a very great degree? YES....to a VERY GREAT DEGREE!
If the problem isn't tape shed, but signal path, is the TEAC A3340S a machine worth putting a lot of work into, or just worth throwing at that idiot who decided to make a live action Garfield film?BEST TO THROW IT
Should I buy some new tapes or just bake the ones I have, which are mostly from the mid 80's, and mostly BASF--?BUY NEW TAPES
The A3340S is ancient buy todays standards....You can get a Tascam 424MKIII for $300.00 American dollars and save yourself a butt-load of trouble. If you want a reel to reel you can get a Tascam TSR-8 for around $500.00. It's an 8 track 1/2 inch 15ips recording deck that outperforms the A3340S buy a thousand times. Also the Tascam 34 is a good 4-track reel to reel (1/4 inch)
If you are going to keep the 3340 then get some new tape! Using old tape on these decks is REALLY A BAD IDEA. When the old tape sheds it clogs EVERYTHING up! Hope this helps
Holy Shit! Are those real?
Rev. Muddy
