Old 06-10-2004
starber's Avatar
starber starber is offline
Junior Member
starber is on a distinguished road
monitors: horizonal vs vertical
I see monitors used both horizontally and vertically. Preferences? Reasons?
Old 06-10-2004
rfarris rfarris is offline
Newbie
rfarris is on a distinguished road
It depends on the application. I have a Samsung 191T+ that swivels, and if I'm doing something document oriented I swivel it to the portrait mode.
On the other hand, if I'm editing with a wavefile editor, I change to landscape mode, which is the natural orientation for that task.
Having said that, I spend most of my time with my main monitor in portrait mode.
I suppose I should admit that I actually have a three-monitor setup. Portrait in the middle and landscape on each side. :-)
-- Rick
Old 06-10-2004
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
Are you talking about speakers or displays?
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 06-10-2004
starber's Avatar
Junior Member
oops, my fault!
I was refering to speakers in a control room environment.
Old 06-10-2004
Harvey Gerst Harvey Gerst is offline
Huh ???
Harvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond reputeHarvey Gerst has a reputation beyond repute
"Most" pro studios (but not "all" pro studios) place nearfield speakers on their sides, with the tweeters on the inside. Lotsa reasons why, but it gets technical.
Old 06-10-2004
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
Really? I thought that they were supposed to be upright but if they had to be on their sides, the tweeters were to go to the outside. Man was I wrong.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 06-10-2004
vestast's Avatar
vestast vestast is offline
Gassy Member
vestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond reputevestast has a reputation beyond repute
Harvey - could you explain than more ? Everything I've read has said that the tweeters should be on the outside. I know enough about you to know that if your saying that then there might be a reason behind it..
Thanks
Old 06-10-2004
Cyrokk's Avatar
Cyrokk Cyrokk is offline
Farce of Nature
Cyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond reputeCyrokk has a reputation beyond repute
I think it has to do with how the sound is dispersed from the speaker, which is in turned based on how the monitor is constructed by the manufacturer. The instructions that came with my Tannoys went into quite a bit of detail as to why this particular brand of speaker should stand vertically. I imagine the others have similar tailored instructions.
Cy
Cy's Tracks
All music posted by Cyrokk is Copyright ©2006, 2007
Hell's Acre: Music to headbang and break stuff
"I don't like stuff that sucks"-Butthead
"You're a fart pocket in a turd, fuck off!!!"-Fancy
Old 06-10-2004
LooneyTunez's Avatar
LooneyTunez LooneyTunez is offline
Dedicated Member
LooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of light
Unless a speaker is specifically designed for horizontal placement, then it should be vertically placed. Most two-way nearfield monitors are designed for vertical placement because the drivers are aligned vertically. Yamaha's old NS10's are a good example of speakers designed for horizontal placement, because the tweeter is offset from the woofer in the horizontal plane.
The somewhat technical reason for not placing a vertical speaker on it's side is because of comb filtering (peaks and dips in the frequency response) that will occur by having the sound of the woofer and tweeter crossing each other as it travels to your ears (For example, if the tweeter is on the outside, the sound of the tweeter will have to travel through the sound of the woofer on it way to your mixing position). If the two drivers are offet (Like the NS10's - tweeter above the woofer), this comb filtering is minimized.
Let's hope Barefoot (Thomas) can chime in, as his technical explaination will be much more - um - technical.
My Work:
Kraft Music Sales
My Hobby:
The Mix Posse
Old 06-10-2004
Huh ???
When you have the nearfields vertical, the speaker usually has maximum horizontal dispersion. However in the nearfield, the width of the "sweet spot" is less of a concern, compared to imaging and detail. Putting the cabinets horizontal (with the tweeters inside) provides maximum detail without the woofer modulating the tweeter, but at the cost of decreased dispersion and increased reflections off the console and the ceiling.
Vertical placement requires positioning the speakers so that your ear is level with the space between the woofer and the tweeter, but often, you sit too low for that positioning. Horizontal placement allows you to rotate the speakers easily to achieve that positioning. Finally, vertical placement is simply too easy to knock over.
Bottom line: Is it an audible difference? Sometimes yes, but sometimes other problems will mask the differences. Try them in different positions and see if you hear a difference. If not, use them in whatever position you find the most esthetically pleasing.
We aligned our NS-10s with a low-powered laser pointer at the speaker position, aimed at the engineer's ears. Once they were positioned above the meter bridge, we cut the wood supports in such a way as to insure we'd always be able to get them re-aligned quickly, even if they got bumped.
Was the laser alignment stuff overkill? You bet your ass it was, but we had a lot of fun playing with the laser, and the studio cat really enjoyed the whole procedure.
Old 06-10-2004
turnitdown's Avatar
turnitdown turnitdown is offline
$10 PayPal=Your Ad Here!!
Location: Foothills of the Sierras, Northern Calif. USA
turnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these partsturnitdown is infamous around these parts
Red face
Aren't studio cats great???? (Except for the shedding of course...)
I like mine so much, I bought a matched pair!!!!!
If Bruce Springsteen is the Boss.... I quit.....
Oh, and PMC#11 8th place winner!!
Learn the scary truth about "The Religion Of Peace"... click here
  #12
Old 06-10-2004
vestast's Avatar
Gassy Member
Some very cool info in this thread. My monitors came with instructions that said they could be used either vertical or horizontal, and to be honest I always thought they sounded better horizontal, but never left them that way because I was always worried that I would miss things in the mix. I might have to try a few experiments this weekend.
Thanks for all the info (even though I didn't start this thread !)
  #13
Old 06-11-2004
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
Im happy to see that Harvey uses NS10 monitors too...and all this talk about them being shit
wayne
  #14
Old 06-11-2004
Huh ???
They are shit, but they tell you a lot about what's going on in the midrange of the music, kinda like watching TV with a magnifying glass focused on one part of the screen; worthless for the big picture, but great for detail in one part of the screen.
  #15
Old 06-11-2004
ds21 ds21 is offline
Force of Nature
ds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond repute
Though the explanations above where not exactly correct, what matters is the environment and how they will sound in it. They might even sound good upside-down as the Mission studio monitors are designed.
True Creation Comes Of Nothingness
-Winner Mix Contest 8-
-Winner Mix Contest 11-
  #16
Old 06-11-2004
Huh ???
Originally Posted by ds21
Though the explanations above were not exactly correct, what matters is the environment and how they will sound in it. They might even sound good upside-down as the Mission studio monitors are designed.
"were not exactly correct"? Where exactly did I screw up?
And yes, if the tweeters are too high in relation to your ears, inverting the speakers (putting the tweeters at the bottom) would be a possible solution. I think I covered this point when I said, "Vertical placement requires positioning the speakers so that your ear is level with the space between the woofer and the tweeter." Obviously, if the speakers are inverted, that might satisfy that requirement.
So what wasn't "exactly correct"?
  #17
Old 06-11-2004
Force of Nature
The modulation I belive your refering to , is actually "time/phase alignment", and related is "lobing" just setting the speakers on their sides will not effect either depending on where it's measured form and what reflections there are, I guess to get the point across modulation is as good a term as any.The dispersion is actually the "power response" of a speaker, basically the same thing as the polar response of a microphone. So it's the relationship to it's surrounding and the listener, and not the orientation of the speaker that makes the difference.
  #18
Old 06-11-2004
Huh ???
No, there's also a "modulation effect" when the weaker, limited dispersion treble response has to pass thru the wider dispersing, more powerful bass response to reach the listener's ears. "Power response" in speakers usually refers to the differences between the response at 1W@1m and the response at higher levels.
Polar response, (or "off-axis response") would be the correct terms, but dispersion is the most recognized description of the effect. There are also edge defractions and changes in response whenever the sound reaches any nearby surface or boundry that is not on the same plane as the speakers.
"Time/phase alignment" is different (and pretty much out of the end user's control), since you're talking about the actual distance from the voice coils to the end of the radiating surface to align the phase response at the crossover point of both drivers, which is a function of the manufacturer's choice (and positioning) of the active speaker elements. That was all covered in Ed Long's paper on time alignment, back in the 70's.
Your statement, "So it's the relationship to it's surrounding and the listener, and not the orientation of the speaker that makes the difference" is misleading (especially in the case of nearfields), since the orientation of the speakers can dramatically change the relationship of the loudspeakers to the listener, when the speakers are only a few feet away from the user.
As I said in my first post on this subject, " Lotsa reasons why, but it gets technical."
Respectfully,
  #19
Old 06-11-2004
Force of Nature
"The total energy radiated by a speaker in all directions is called its "Power Response". The Home THX Diffuse Surround Speaker is required to have a flat power response. This means that the total energy radiated by the speaker (in front, above, below, behind, and to the sides) must together average a flat frequency response. With the total speaker energy being flat, a listener anywhere within the surround speaker's null area will hear flat frequency response."
This is directly from the THX website. Just one of the first one's to come up.
"Off-axis response" is different from "power response" and is a more common term in speakers design but not the same.
this is time-alignment, yes, but the acoustical center of a driver (which is what you want) you have to measure where it is, for instance, you can't just say it's center of the voicecoil. The end-user and the relative position from woofer and tweeter will have a direct effect on the time-alignment of the speaker, as you said it is the "actual distance" of the A.C. of the drivers that's why Theil speakers for instance have sloped baffles, if you aim your speakers so the tweeters are further away than the woofers then you can get closer to time-aligned, BUT I'M NOT SAYING TO DO THIS.
"align the phase response at the crossover point of both drivers, which is a function of the manufacturer's choice (and positioning) of the active speaker elements. That was all covered in Ed Long's paper on time alignment, back in the 70's.
A speaker can be time-aligned but not phase-aligned.
Lobing is very commonly talked about, do a search.
After toying and designing speakers (not as a Professional) for over 20 years, I've learned a few things, if you look things up and do research and find discrepancies in my terms let me know, I'm always willing to admit I'm wrong if shown the facts.
P.S. on one of the speakers design forums I frequent, they where just talking about the NS10 and saying that's the reason certain recordings sound so bad, you know all the things people say when they don't know the benefit of them, or when and what people use them for, I tried to let them know but they just didn't want to see.
  #20
Old 06-12-2004
Huh ???
Apples and oranges. Apparently, "power response" (in the sense you are using it) is a new term to describe integrated response curves in the entire room and using eq's to compensate for various response anomolies. It seems to be a home theater term to describe the integration of speakers in a 5.1 surround sound system.
A nearfield speaker (by definition) should be close enough so that room responses are not considered, because the listener is close enough to the speaker to not have the first reflections unduly alter the sound. Unlike your definition of the THX power response effect, the room is taken out of the equation.
This is straying far from the original question. The simple solution for the original questioner is try it in different positions and see which position sounds best in his situation.
  #21
Old 06-12-2004
Force of Nature
Ok here's an apple:
http://www.genelec.com/ht/pdf/G0001.pdf
After doing many acoustical measurments in my own speaker designing, and knowing that you have to use have a gated signal to get rid of the room response/reflections, I have to disagree with you here.
Totally I agree with you here
If you want to find out more, I would suggest looking at some of the DIY speaker design forums online, some of which have MAJOR pro designers drop by, and some of the members are published in mags and AES. In fact you could help me shed some light on the recording process to them!
  #22
Old 06-12-2004
Huh ???
Nope, it's still an orange; they're talking about studio monitors, not nearfields.
Yes, if you're doing impulse testing of loudspeakers, you have to limit the window by gating; has nothing to do with this discussion, since nearfields are intended to take the room out of the equation.
Actually, I've designed quite a few speakers (and speaker systems) in my younger days. A few of them are still pretty well regarded, even today, more than 40+ years later.
As I said, we've drifted off the original question, and I certainly don't want to get into an argument here.
  #23
Old 06-12-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
...some of which have MAJOR pro designers drop by, and some of the members are published in mags and AES. In fact you could help me shed some light on the recording process to them!
Do you have any idea who you're talking to here?
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
  #24
Old 06-12-2004
Force of Nature
as the link above shows "Power response" applies to other speakers besides 5.1 surround, you'll also find it for regular consumer stereo speakers and pa speakers, but if you beleive it doean't apply to nearfield, oh well...
Key word being intended.
I'll say, intended to minimize the rooms effect.
Yes, but I haven't seen anything to backup his statements, and no I won't just take his word for it (as nobody should just take mine), , harvey's right this is not the place to teach/discuss about such things. But you, Harvey or anyone else are welcome to chat with others with alot more knowledge then me.
a link of links:
http://www.audiodiycentral.com/jpo-chat.shtml
This one being one of my fav's:
http://www.madisound.com/cgi-bin/discuss.cgi
  #25
Old 06-12-2004
Huh ???
Well, hopefully, the original poster got his question answered, and probably a lot more than he bargained for.
As far as visiting the speaker groups, I'll pass on that, since there's more "religious" fervor there than I can take these days. I only drop in on the JBL and Acoustic Control forums about once a month now, just too damn old, I guess.
The only thing I'm doing these days in the way of speaker design, is a nearfield monitor for one of the major manufacturers, then I'm out of the design business. I've been working on this thing for a couple of years now, and hopefully, it's gonna turn a lot of heads, if I can work out the final design and get the patents in place. The days really do get shorter as you grow older. I hope to see it hit the market while I'm still around.
Ds21, thank you for an interesting discussion, and we'll just hafta "agree to disagree" on some of the points raised.
