Old 06-05-2004
chamelious chamelious is offline
www.thesunexplodes.com
chamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond reputechamelious has a reputation beyond repute
Monitors- Active vs Passive
What are the pros/cons of using passive monitors? Upto now i thought passive would be too expensive, but looking at the samson passive resolv's and their amps to go with it, it looks a little more attractive.
Old 06-05-2004
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Talking
Yo Cham:
According to Massive Master, he prefers the passive but has both types in his studio.
I started out with Yorkville passives and they were fine. I just switched to KRK ST8s which have a larger woofer [8" vs. 6.5 for the Yorks] and they do a great job.
You might try to get some monitor auditions at a vendor and see what your ears think and how the boxes will fit into your working area.
Green Hornet
Old 06-05-2004
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
The advantage of passives are usually cost. Some real high end monitors are made by people who don't make amps, so those are passive by default. The disadvantage is that the amp you use may not be adequate or well matched to the speaker. An amp can be expesnsive, too. Another disadvantage is that the amp takes up additional space.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 06-05-2004
Ok thanks, so for someone on a budget of less than £300 actives would seem to be the way to go, ive been lookin at models like the benhringer truths, alesis monitor 1's, samson resolvs, etc.
Old 06-05-2004
Talking
Yo Cham:
ACTIVES would be more expensive than passives.
I'll have a Laphroig neat.
Green Hornet
Old 06-05-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Out of the three you mention, you're *probably* going to like the Truths the best. For sure in the low end content...
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 06-05-2004
foreverdown foreverdown is offline
Senior Member
foreverdown is on a distinguished road
I was looking at the truths, but decided against them because someone was telling me all the problems they have had with them. Granted its only one opinion, but all the reviews you read are only the reviews after a little use. Down the road I am guessing is where the problems are. Also the cheaper active monitors tend to have colored sound. I decided against the M-Audio BX5's and the Behringer Truths after going to guitar center and checking out the KRK ST8's. The sounded amazing. As well as the ST6's. So now I am going to get a power amp on ebay and then get the ST8's. The ST8's are 250 a pair and the ST6's are 200. So if you get the ST6's you can get a decent amp on ebay for 100 dollars or so. I would recommend scrounging up the extra 50 for the ST8's though (if you can). oh, the prices I mentioned are USD.
http://purevolume.com/foreverdown <-- my music
Old 06-06-2004
apl's Avatar
apl apl is offline
Stand Up Comity
Hey, these amps are great. 200 very clean watts per channel, and only 7" on a side.
My tunes. Thanks!
NB
DA BEARS!
