Hard limiting..Compressor
Hi all...new user here...and absolutely enjoying the C.E.P. 2.0 program...My question may be silly to some, but to me it's not...what does the "hard limiting" effect actually do? And what is a good setting for it... if it is a compressor type effect? and... I've been looking for the compressor on C.E.P. 2.0 and can't find it in any effects group. If anyone could help me with these two questions I would greatly appreciate it. Secondly; It seems when I bounce 2 tracks to one track... I can't use the original two tracks anymore...even after deleting the old tracks I get a "clip" and a pop whenever I start to use the old tracks that I just bounced from...so... I've been muting them and not using any tracks that I've bounced from and it seems to fix the problem, but it's terribly annoying to have 15 tracks spread out over 25 tracks lol if you know what I mean...
Comp info celeron 500 mhz 13 gb hd 192 ram |
As for what settings to use on the limiter, it totally depends on how loud your file is before you limit it. I like to just kinda' eyball it to start with, and (ignoring spikes), if it just LOOKS like most of it is around -10db, then I'll use an output setting of 10db to push most of it up to 0db. THIS IS JUST A ROUGH STARTING POINT...BE SURE TO LISTEN TO HOW IT SOUNDS AND COMPARE IT WITH OTHER MIXES THAT YOU LIKE. The hard limiter is located under "Effects >> Amplitude >> Hard Limiting The "normal" compressor is located under "Effects >> Amplitude >> Dynamics Processing. Like any compression, don't overdo limiting, b/c if you do, it can distort the file...and even if it doesn't distort, you really shouldn't push the crap out of it because it'll kill the dynamics of your tune. Quote:
As for why it does this? I have no idea, but your computer's really not up to par for the software...I always had a lot more problems before I got a new box. Good luck. Chris
thanks...
Thanks guys for answering my questions... and I am getting a better pc to run C.E.P.2.0 as I've noticed some crashing and track slippage...after the pc crashes ..my tracks don't sync up anymore and I have to edit microseconds out of them to re-allign them...so I appreciate your help
DoubleNeck |
