"Free Hard Drive Space"
Hi there
I'm using Cool Edit 1.0 (yeah, I know it's archaic...) to edit some djs sets, adding some vocal .wav files using only two channels (one for the set another for the "addings") When I get to edit the last part of the set (around 75' long) a "free some hard drive space" advice keeps popping up... I've checked on my two disks and I still have plenty of space (more than 3 gb each) and my RAM is 128 MB (which I guess is enough) The Help @ Cool Edit says: "try increasing the Peaks Cache in /Options/Settings/System to 1024 or even 1536 or 2048 to use less RAM. " I've done this and it still doesn't work... It also advices to: " try reducing the Wave Cache size /Options/Settings/System and/or increasing the virtual memory settings for your system." and it still won't work. What can I do? Should I try using Cool Edit 2.0? I'm desperate, please if possible, answer this to uter@perlamarina.com I need to finish some works and I'm running short of time... |
As a way around it, I would think you could deselect the "enable undo" button, but every edit you make will be permanent. Lemme' know if I misread.
I guess it can't be a matter of Hard Disk space because even if I keep saving and saving I check and it says i've got like 4 gb free still on each disk...
dunno mate! |
how big are your hd's? i mean...the original size...it definitely seems like a hard drive space problem... I don't like to screw around with anything less than about 20 gb free... I guess thats my ocd speaking though.
Flush the file everytime you make an edit you're positive is going to stay...
Otherwise, I'd say it's time to upgrade your HD.
http://www.changehiphop.com/images/pics/Signature.jpg Preview of the new Album here!!! Mixing and Mastering services for your project, contact change@changehiphop.com |
