Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-19-2004
StupidKid StupidKid is offline
Newbie
StupidKid is on a distinguished road
Question about hooking up inserts.
I was just curious on how could I hook my dbx compressor to my mixer so that i can compress my bass drum, and snare drum. My mixer has 2 inserts, and 2 sets of aux in and aux returns. My compressor has inserts, input and output. I just dont know what wire goes where. and how do i make the signal go to the compressor and back?? Thanks
Old 05-19-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
You need an insert cable - Likely, 1/4" TRS to dual 1/4" TS. One tip goes to the TRS tip, the other tip goes to the TRS ring.
Plug the cable into the "insert" on the console (keep in mind that this would be at the track level if you're trying to compress certain tracks only).
"Normally" on most U.S. and British consoles, TIP goes To InPut and a RING completes a circle. That's about the simplest way I can come up with to remember if you don't use them very often.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 05-21-2004
wimat wimat is offline
Junior Member
wimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond reputewimat has a reputation beyond repute
In case that's over your head.... you need a cable that has one 1/4" male connector with two rings one one end (that's the TRS, or balanced end) and two 1/4" connectors with one ring (the TS connector) on the other side. It's a y-cable, like this:
http://www.hosatech.com/hosa/product...nd_return.html
Old 05-21-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
You will need two compressors to do your snare and kick seperately unless your DBX has two mono channels.
