Go Back   Home Recording > User Forums by Brand > n-track User Forum
     Audiofanzine Music-software Music-software News Music-software Medias Music-software Tests Music-software Articles Music-software User Reviews Music-software Classifieds Ads
Old 05-16-2004
bdemenil bdemenil is offline
Force of Nature
bdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond reputebdemenil has a reputation beyond repute
Unhappy Ntrack and Motu problems
I just got a Motu HD192 with the PCI-424 card. I have no problem with playback using either WDM or ASIO drivers, but recording does not work well with either. With WDM, I'm getting the old track-offset problem. With ASIO, if I try recording 7 tracks of of 96K 24bit over an existing 7 tracks (these numbers just happen to be what I'm testing with), the playback skips every 15secs or so.
With Cubase, using the same ASIO drivers, I can successfully record up to 30 something simultaneous tracks before cubase tells me my system is ovleroading.
Is anyone out there using the HD192 or any other PCI-424 based motu interface with NTrack?
Old 05-17-2004
crankz1's Avatar
crankz1 crankz1 is offline
crankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond reputecrankz1 has a reputation beyond repute
In n-Tracks preferences go to options, then deselect both options for "Use system time for". Also, you may try playing with the buffer settings. Do several test recordings at different buffer settings. You should be able to find a happy medium between high and low settings.
HTH
-Ken
~It all works out in the end~
Old 05-17-2004
Force of Nature
from what I can tell, you can't change buffer setting on NTrack when using ASIO drivers. Doing so will cause the program to crash. I have the highest buffer settings selected on PCI-424 control panel.
Old 05-17-2004
crankz1's Avatar
You are correct ASIO buffers are set via MOTU control panel... Also Highest buffers aren't always the way to go .... Try several different settings.
Old 05-17-2004
crankz1's Avatar
You might also try doing a quick defrag of your drives. Unless you have already done so.
