Go Back   Home Recording > General Discussions > Digital Recording & Computers
Reply    Audiofanzine Computer-music Computer-music News Computer-music Medias Computer-music Tests Computer-music Articles Computer-music User Reviews Computer-music Classifieds Ads
Old 05-12-2004
vic91218 vic91218 is offline
Junior Member
vic91218 is on a distinguished road
Layla20 and CEP2.1
Hey guys....
I've been using CEP2.1 for a while now and havehad good results using my Echo Layla sound card/interface. My question is this....
Supposingly the layla has 8inputs/8outputs. However, when I go to select which channel/inputs I want to record in CEP, I can only select the channels in pairs. For example....
Track 1
I can select Layla20 1-2 or Layla20 3-4, Layla20 5-6, and/or Layla20 7-8. But I cannot select just channel 1. I'm trying to record drums and up till now I have not needed any more seperate inputs that the 4 it's provided. Is there anyway I can seperate these inputs and put them on seperate tracks?
Thanks...I hope that was clear enough. hehe
-Vic
Old 05-12-2004
brzilian brzilian is online now
2.5K Gold Member
brzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond reputebrzilian has a reputation beyond repute
Sounds like CEP only records in stereo. I have no experience with it, but I would assume it has an option to split a stereo track into 2 mono tracks.
Old 05-12-2004
lpdeluxe's Avatar
lpdeluxe lpdeluxe is offline
The Precision Bass Guy
lpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond repute
Go to Options/Settings/Multitrack and see if the default in the middle on the right is set to "Stereo". If so, reset it to "Mono". You should then be able to record 2 discrete tracks.
Old 05-12-2004
Junior Member
Thanks for the tips...
I changed the default to mono from stereo, however I still cannot choose between channel in 1 or 2. Just 1-2 together as a stereo pair. This is the same for my echo Mia card. It has two inputs....but I can't record two seperate tracks at the same time through CEP2.1 because it will only allow me to select Mia 1-2 as a stereo channel. ?? I'm at a loss here. =( Any other tips would be greatly appreciated. =)
-Vic
Old 05-12-2004
lpdeluxe's Avatar
Try selecting 1L for the first track's recording source and 1R for the second's. That's how I record 2 mono channels.
Old 05-12-2004
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
The Delta 66 presents itself in SONAR as 1/2 and 3/4 stereo pairs, but I can select just the right or left side of each pair when recording a mono track. I have Cool Edit 2000, and I see the same thing you're describing -- I can select a pair of inputs. But when I select to record a Mono track, I get whatever's coming in on the one side. I'm not sure if this is the two inputs (one with no signal) summed to mono or what.
Old 05-12-2004
Junior Member
Hmm. That may do it! I'll give that a shot tonight. Thanks =)
