Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-11-2004
ScooterMcTiny ScooterMcTiny is offline
Newbie
ScooterMcTiny is on a distinguished road
Why do I have to mix on monitors?
Before you crucify me, I understand I need to mix on monitors. Well not need, but you know what I mean. It's my parents that don't. I know what I've read, and it makes sense to be, but with them, I need concrete data or reasons why it's better to mix on monitors rather than hifi's. Thanks for your help,
Jackson
Old 05-11-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Well you have 2 choices... mix on monitors/speakers, or mix on headphones.
Have them read this article (Whad'ya Mean I Can't Mix With Headphones????) for reasons why headphone mixing is not really viable.... that means the only choice left is monitors!
Old 05-11-2004
Newbie
Thanks Blue Bear, I will have them do that. But I guess more of what I'm looking for is the choice between speakers/actual studio monitors and why they are better. Thanks again, Jackson
Old 05-11-2004
strmkr's Avatar
strmkr strmkr is offline
Prodigal Member
strmkr is on a distinguished road
There's a great line at the end of Bear's article about "trying to hammer a nail with a screwdriver". Same thing applies to the difference between stereo speakers and studio monitors. Stereo speakers are designed to give a pleasurable listening experience in your living room. Most stereo speakers are designed to accentuate certain parts of the frequency range, like hyping the bass or highs etc. In other words, to make the sound sound a particular way.
Nearfield monitors are designed to give a neutral response in your control room. The goal of a good set of monitors is to present the sound as it is without adding any hype or coloration so you can make well informed sonic decisions about what your'e recording and mixing. The end result,hopefully, is your mix translating well to all the different playback systems it is played on.
Good luck!
Old 05-11-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Tell your parents that with regular speakers it will take you longer to mix because you will have to be constantly checking your mixes on different systems. With real monitors and a treated room you should be able to get a more accurate mix in less time.
The end result is that with real monitors your parents won't have to listen to the same song over and over as many times.
Old 05-11-2004
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
He nailed it, Scooter.
What's likely going to happen when you first start mixing on hi-fi speakers is your mixes will sound great on those speakers, but then when you try playing it in your friend's car or your girlfriend's walkman, it's going to sound way different to you -- and probably not as good.
Old 05-12-2004
skim skim is offline
Junior Member
skim is on a distinguished road
How much truth is there in the notion that you can mix to a reference song, in place of expensive monitors?
That is, take a song that you think is great engineering, then play them on your $50 crappy speakers. If your mix sounds crappy in the same way the great song sounds crappy, then you've got a good mix.
Take this question with a grain of salt, you purists out there. Obviously the ideal situation is to go with the monitors. Realistically speaking, how useful can this technique be, and what are some situations where it just flat out won't work?
After all, we listen to music for the most part on crappy speakers.
http://www.stevenkimband.com/
Old 05-13-2004
chessrock's Avatar
Banned
Skim,
If your goal is to make things as difficult as possible for yourself because maybe you just need more challenge in your life, then I'd suppose this method might be appealing.
For those of us who like things to be simpler, streamlined and just more effective (maybe we have other things in life that are important), then you're probably better off just going the monitor route.
If you're trying to make mixing decisions based on a monitoring setup that is leaving it's own tailored sonic imprint on the sound, it's going to be very time-consuming and difficult to "learn." Not to say it can't be done, because I know a lot of people who have done some pretty amazing things in their lives . . . but if you've got that kind of time and motivation, why not just use it to make a few extra bucks for a real monitoring system?
Life will be so much simpler for you.
Yes, most people do listen back on crappy speakers, but again the idea is to get your mixes to translate well to as many crappy speakers as possible. Just because they sound fine on one set of crappy speakers doesn't mean it won't sound horrid on another, yet different set of crappy speakers.
Old 05-13-2004
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Realistically, most anything sounds crappy on crappy monitors.
If you're listening to a good mix through monitors that are light in the lows, you could do a mix that's heavy in the lows and you won't be able to hear the difference because the monitors can't reproduce it anyway.
That's just one example - There are more, but time is short.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 05-13-2004
Ethan Winer's Avatar
Ethan Winer Ethan Winer is offline
Why 2K?
Ethan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond reputeEthan Winer has a reputation beyond repute
Lightbulb
Skim,
> How much truth is there in the notion that you can mix to a reference song, in place of expensive monitors? <
None.
There are two different but related problems. One problem is that poor speakers have a poor frequency response, and the distortion is also likely very high too. The other issue, which is just as important, is your room is skewing the response even more than the speakers.
Either way, the main problem with using a good sounding commercial CD as a reference is the skewed room response is frequency dependant. So the reference track will have to be in the exact same musical key to be of any value. Even then, it's poor practice to mix in a room whose low frequency response varies up and down by 30 dB throughout the entre low end.
--Ethan
The acoustic treatment experts
Old 05-13-2004
distortedrumble's Avatar
distortedrumble distortedrumble is offline
all up in yo grill!
distortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond reputedistortedrumble has a reputation beyond repute
go ahead and set up a power point presentation at the dinner table....wear a suit and everything. dinner presentations make it look serious
  #12
Old 05-13-2004
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
Massive is right.
You can only work with that which you can hear. If the speakers are distorting your perspective on the sound, matching those distortions isn't necessarily going to give you an equivalent product.
To give a different analogy (something I seem to be fond of doing lately). If you were walking down the beach with seriously smudged, scratched, and cracked glasses, what you took for Pamela Anderson may actually be some 90 year old grandmother carrying beachballs.
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
  #13
Old 05-13-2004
How about trying to smell the difference between red and yellow roses while you have a cold...
  #14
Old 05-13-2004
all up in yo grill!
.........theres a difference between the smell of yellow and red roses?
  #15
Old 05-13-2004
Picky, picky... Okay -
Trying to smell the difference between roses and daisies in a sewer.
  #16
Old 05-14-2004
chessrock's Avatar
Banned
Talking
I did't know they grew in a sewer.
  #17
Old 05-14-2004
lpdeluxe's Avatar
lpdeluxe lpdeluxe is offline
The Precision Bass Guy
lpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond reputelpdeluxe has a reputation beyond repute
Talking
...or trying to judge a painting framed behind dirty glass.
  #18
Old 05-14-2004
Massive -
Better to leave the analogies with someone else I think ...
Another question, which sounds better, analogies or digitalies?
Tom Volpicelli
MySpace:
  #19
Old 05-14-2004
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
you can mix on whatever you want. if it works it works. but it most likely won't....
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
  #20
Old 05-14-2004
Ah-HA! You're correct! Someone has to put them there.
HOWEVER - The sound that comes from your monitors is put there, also.
Yeah, maybe I just better quit...
  #21
Old 05-14-2004
packratlouie packratlouie is offline
Senior Member
packratlouie has a spectacular aura aboutpackratlouie has a spectacular aura aboutpackratlouie has a spectacular aura about
This is a pretty basic answer. If you mix on monitors which are flat, you are hearing what the audio really sounds like. If you choose monitors(or computer speakers for that matter) which have a high end lift, you will want to compensate for it in your mix by taking down the highs, when in fact they are at the right level, but you cannot tell because of the lift.
The reason you want to mix on studio monitors vs computer speakers is because if you mixon something flat, and then after the mix it is played on something with certain frequency notches, the flatness of the speaker you mixed on will have compensated already. Of course Ethan Winer mentioned an important factor regarding the room dymanics, as with bass you can definitely be hearing incorrect things if your room isnt treated... and we arent talking one or two dB we are talking ten to fifteen. My reccommendation? If you are serious in any way about mixing get a pair of monitors(m-audio studiophile), or a passive pair of tannoy's with a decent alesis amp or something. And if you want to get a better idea of your actual mix, go to Ethan Winer's site and read about using sine waves and an omnidirectional mic to test your rooms bass response. There are a few programs out there which will also calculate frequency nodes in your room where there is a severe drop in dB... just make sure they dont exist where you are mixing... but in all of this, if you want good solid advice ask Ethan Winer.
www.ethanwiner.com
use the search feature on there
Tyler Ferrari
  #22
Old 05-20-2004
Dioxide's Avatar
Dioxide Dioxide is offline
Senior Member
Dioxide is on a distinguished road
Ok so what about this ....... I'm what you call a broke ass bitch therfore I can't afford monitors at this time. But I have some really sweet Pioneers and a nice graphic eq is it possible to use the equalizer to flatten them to a truer sound and thus have me some makeshift monitors???? I know this is not the Ideal way to go but I need some thing that can tide me over till the recording fairy pulls all my teeth and leaves me some money.
DIOXIDE
"Ill make weapons from my imperfections"
  #23
Old 05-20-2004
No... not really.......
  #24
Old 05-20-2004
Dioxide's Avatar
Senior Member
Thats what I thought (gave it a try though)
DIOXIDE
  #25
Old 05-22-2004
Dioxide's Avatar
Senior Member
OK I think I'm able to talk my wife into letting me get a set of monitors using this thread so What I would like to know is what is the difference between active and a passive. I mean I know what active and passive are but what is the difference in the monitor world. The best thing I can find on my budget are a a pair of Samson Resolv 65a's the actives are 299 and the passive are 199.
DIOXIDE
