Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-09-2004
bsr2002's Avatar
bsr2002 bsr2002 is offline
Denny Crane
bsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond repute
Talking Noise Eliminating Software
Is there a cheaper program to use other than SoftSoap?
Thanks
Unwanted e-mail = SPAM on the internet (not legal)
Infomercials = SPAM on the airwaves (Legal)
Junkmail = SPAM in your mailbox at home (Legal)
Check Out My Tunes
Old 05-10-2004
ryanlikestorock ryanlikestorock is offline
Force of Nature
ryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to behold
I find most of the noise reduction programs leave those "singing robot" sounds far too often. I'm not exactly sure what that is, but here's a pretty easy way to avoid it most of the time.
Save the file you're working on. Using a noise reduction program, select an appropriate amount of noise reduction, but choose to "leave only noise" instead of taking it out of the recording. Then, invert the noise signal, copy the entire signal to your clipboard (ctrl+c) and close the file without saving.
Open the original file and paste the inverted noise file overtop of the original. This SHOULD cancel out the noise without leaving much of the digital crappiness that most noise reduction programs create.
I've only done this a couple times and it's always been pretty good. Let me know how it works for you.
Old 05-10-2004
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
The best noise reduction is not to record it in the first place................
Plug-ins after the fact usually tend to leave artifacts.......
Old 05-10-2004
malcolm123's Avatar
malcolm123 malcolm123 is offline
Force of Nature
malcolm123 is on a distinguished road
Yep !!!
Clean signal,, less noise
Malcolm
Strap it Cross Dat Stereo Buss !!
Old 05-10-2004
bsr2002's Avatar
Denny Crane
Smile
I have an 8 track multitracker and it makes like a little chirping noise, I didn't notice it before because I was recording multiple instruments thru a mixer to the 8 track recorder. I only noticed this when I decided to record just a solo piano.
Check Out My Tunes
Old 05-10-2004
strmkr's Avatar
strmkr strmkr is offline
Prodigal Member
strmkr is on a distinguished road
Are you sure the noise is coming from the machine and not the piano? If you didn't find it on any of the soloed tracks from your previous recordings, it might be something in the signal chain on this particular recording rather than a fault in the machine itself.
I'd look at the levels too, make sure you aren't clipping, not just onthe track level meter, but at the input as well.
Good luck!
Old 05-10-2004
kylen kylen is offline
Force of Nature
kylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond repute
Well here's a trick I just did with PSP MixTreble that sounded pretty good to my ears - I checked this out and set it up in headphones so I think the results were even better.
I do a lot of remastering (non-pro just kind of hacking around for myself and friends) of tape to digital conversions. So the big thing there of course is broadband noise such as tape hiss.
The problem with all denoisers and hiss reduction is that it removes part of the good stuff. To prevent this you can obviously only turn on noise reduction when you hear noise that must be reduced - simple eh ?
If you have a host that allows VST automation, I use Sonar3, then insert a good denoiser across the track. PSP MixTreble has a hiss reduction section that is very good, what's equally as good is the VST version of the plugin is automatable.
I automate the attenuation parameter and turn it on only when it is necessary, in Sonar3 you can set automation control points in the same track as the audio so you can really fine tune it and make it very transparent.
That's the 2nd best way - of course the 1st best way like everybody else said is to track down the source of the problem and eliminate it before it gets committed to a recording...
Good luck denoising - a thankless and costly (timewise) job for sure...
ED: Oops forgot the link...look for MixTreble
http://www.pspaudioware.com/indexen....gins/mix.html;
Old 05-11-2004
bsr2002's Avatar
Denny Crane
Thanks for the responses guys, I will certainly check it out. If any other ideas come to mind please don't hesitate to post.
Thanks Again
Check Out My Tunes
