Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-05-2004
gatorhaus's Avatar
gatorhaus gatorhaus is offline
Dedicated Member
gatorhaus is on a distinguished road
Telephone Voice Sound
I'm working on a Radio Style format CD. On it I have a few telephone interviews, that were not done over the telephone.
How do I get a spoken vocal track to sound like it is on a telephone.
thanks,
larry
Old 05-05-2004
longsoughtfor's Avatar
longsoughtfor longsoughtfor is offline
Searching for the sound
longsoughtfor is on a distinguished road
Telephone is usually heavily compressed and is really just midrange bandpass filtered i.e. no highs and no lows.
Cheers
Kevin.
Old 05-05-2004
faderbug faderbug is offline
faderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond reputefaderbug has a reputation beyond repute
it's relatively easy with an EQ, CUT BASS AND HIGHS AND BOOST THE MIds - i don't know how this happened - most editing software has a EQ preset to do this.
Old 05-05-2004
exactly exactly
Old 05-05-2004
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
A slightly more elaborate but more realistic-sounding method is to unscrew the receiver of your telephone. Using alligator clips connect the line out of your original recording to the telephone. Then call your answering machine and play back the interview as a message. From there you can take the recording off of your answering machine and run it back into the DAW or what you are using to mix.
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 05-05-2004
gatorhaus's Avatar
Dedicated Member
Tom,
Thoe only problem with that is I don't have a old style phone, lol. But thanks for all the replies. I got a good idea of how to do it now. I like the answer machine approach. I might can work that in with a cell phone.
larry
Old 05-05-2004
jazzrich9 jazzrich9 is offline
Senior Member
jazzrich9 is on a distinguished road
you're a crazy guy Tom
That's some of the most creative lo-fi advice I've seen on these forums, seriously, like it was straight out of Tape-Op... I usually don't post useless replies, but that was so useful, it warranted this drivel.
One question, just for fun... could this be done any better with two phones, and reversing the process on the second phone, so you could get a real time feed with that sweet sweet RJ11 sound not to mention limited record time on an answering machine?
anyhow... I'd go with the multi-band compressor myself... if you're working 'in the box' there are several cheap plug-ins that will do the trick...
For some actual settings... set up a Band-pass, Center Frequency = 800, Band Width = 2, Amount = -25dB, and Output Gain = 0dB. -- this gave me something like the sound of listening through a phone. (found the settings on the web, tested them for accuracy, you may have to fidget with them a bit)
hah... not totally useless.
Good luck
Regards,
Rich
Radium Reactor
www.radiumreactor.com
Old 05-05-2004
Hey Rich,
Sure, another way to "skin the cat".
Yet another option was used I believe by John Cuniberti on a Joe Satriani album where he plugged a telephone directly into the board. But you don't get the compression and bandwidth filtering supplied by Ma Bell...
Tom Volpicelli
MySpace:
Old 05-10-2004
jt93 jt93 is offline
Newbie
jt93 is on a distinguished road
quick and dirty, cut everything except 1khz, and boost the hell out of it. real close
)-( 93 )-(
Old 05-10-2004
Jimbo Jones's Avatar
Jimbo Jones Jimbo Jones is offline
smells like ramen
Jimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond reputeJimbo Jones has a reputation beyond repute
I like masteringhouse's idea a lot.
but as far as numbers go, i was taught that the telephone signal had nothing
below 300Hz and nothing above 3000Hz. And when I say nothing, I mean
nothing, no slopes.
I experiemented and it's definitely true, but you need a filter that will do this,
a plugin would work well.
also, compression/distortion usually plays a part too.
