mixing for tape
Do you do anything different mixing-EQ-compression wise when producing cassette tapes or just transfer your CD mixes to tape?
is it worth using metal tapes? the tapes will be played back in a car thanks |
You don't need to add any extra compression - Especially if you're going to hit the tape pretty hard.
I stay away from metal tape - Chrome is about the best multi-purpose tape that I can think of - When possible, I'd use a deck that has a manual high-bias setting, but leave it at regular bias. The highs always seemed more natural that way (instead of actually setting the machine to CrO2). |
I guess what I was wondering is if tapes tend to roll off certain frequencies is it a good idea to boost those with EQ during recording to tape to compensate
My tape deck has an 8 segment meter going from -20 to +6 dB, what's a good level to use? |
I don't "normally" compensate with high bias... Especially if the deck is set for normal.
On the levels, you might have to experiment a bit - If it's pretty dynamic stuff, peaks at +4 on quality tape shouldn't kill you. If it's pretty squished, you may have to go lower. |
