Fiberglass: normal or "quiet"
Hey when ppl talk about 8" fiberglass in bass traps... is it "quiet" one or just normal one?
Cause at my home depot, there's 2 categories of pink fiberglass... there's one called "quiet" and the other is just standard for thermal isolation. The maximum size ive seen for the normal one was 9" & 7/8 and for the "quiet" one it was like 3.5". So are you guys using the normal one or the "quiet" one for absorbers? |
Re: Fiberglass: normal or "quiet"
Shakuan,
> So are you guys using the normal one or the "quiet" one for absorbers? < Neither. Most people use rigid fiberglass, not the fluffy type you find at hardware stores. For more on this see the Acoustics FAQ, second in the list on my Articles page: www.ethanwiner.com/articles.html --Ethan
The acoustic treatment experts |
Ok thanx to you I'm printing 42 pages of ur facoustic FAQ from the job and I'll prolly get caught.
![]() That's weird tho... cuz I remember reading somewhere that 8" fiberglass was more efficient for bass traps since 8" could absorb frequencies as low as 80Hz or something like that. |
Shak, it's true that thicker material absorbs to lower frequencies, this is explained in Ethan's FAQ under Optimizing the Air Gap - however, normal house insulation has a much lower density than the Rigid commercial fiberglas - Owens Corning 703 has 3 Pounds per Cubic Foot (abbreviated PCF), their 705 series has 6 PCF, but normal house insulation has a density of less than 1 PCF. The "quiet" stuff may be as much as 1 PCF, the normal is usually around .5 to .8 PCF.
It's this density that affects how MUCH absorption you get - it's the distance from boundaries (walls) that determines how LOW frequencies will be absorbed. The reason for this is the way absorption works - the sound wave causes air molecules to move back and forth, except where there's a wall they can't move at all. When the sound is moving, anything it has to pass through causes the sound to have to try and move the fibers (interstices) of the material. Doing this causes the sound energy to be converted to heat energy, and since we can't hear heat, there is less sound. The more of these "interstices" (fibers) there are in a given volume of the absorbent, the more sound is absorbed (up to a point) - this is why the denser, Rigid, type of fiberglas does better at absorption. So, basically, thick is better than thin, heavy is better than light, and more air space behind (or just thicker material) lowers the effective absorption frequency. Ethan's FAQ covers most of this, so (if you don't get put in jail for stealing copy paper) keep it handy and read it several times... Steve
Hey, I thought this was gonna be EASY!??! |
