Old 04-30-2004
dietcookie dietcookie is offline
Junior Member
dietcookie is on a distinguished road
neoprene pads / floating floors
If I place the pads underdeath where each joist meets the skid, do I nail the joist to the beam straight through the rubber?
Old 05-01-2004
RICK FITZPATRICK's Avatar
RICK FITZPATRICK RICK FITZPATRICK is offline
Been Here, Posted That
RICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond repute
Huh? Skid? Beam? Where? Nevermind? If you fasten what you are trying to float, to the item you are trying to isolate it from, through the isolation/floatation mechanism, you have now permenantly "coupled" what you were trying to DE-couple. Unless I'm missing something here.
fitZ
alright breaks over, back on your heads!
Old 05-01-2004
Junior Member
fitZ
how would this be sturdy? it's completely made out of wood resting on wood piers.
Old 05-01-2004
WHAT is completely made out of wood? I assume a floor, since skids and piers are not usually referred to in ceiling or roof construction. But we can't read minds.
If you can explain exactly what it is you are building. I AM a builder, and understand perfectly what a joist, skid, pier, rafter, stud, joint, connection, nailing, screwing, bolting and any other normal construction term means. What I don't know, is HOW and WHAT you are building as a SYSTEM. When you refer to a beam, what beam, and where? When you say you are nailing a joist to a "skid", and you are asking if you should nail the joist to the skid, and then refer to a beam, you loose me. Usually a "skid" is resting on a concrete slab, with joists or beams nailed to it. Then joists are USUALLY placed on edge perpendicular to the beam, and a rim joist is naied at the ends. Its obviious that you are planning on floating a floor, or you wouldn't be nailing a joist to a skid. What I don't understand is where the beam comes into play. What is all this assembly goint to rest on? And what is the first thing touching it. And the next thing? Etc.
In essense, what are you trying to isolate from what? If you want an answer that truely helps you, you need to provide more info.
fitZ
Old 05-01-2004
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
Rick, here's the "creme filling" in the Dietcookie -
http://www.johnlsayers.com/phpBB2/viewtopic.php?t=1589
DC, you've posted questions on at least two other BBS's besides John's, but given no background - no one can answer your questions without knowing what you're talking about.
Most of the people who can correctly answer your questions are members of several sites, so your best bet to avoid confusion would be to keep it at John's site - It's up to you, but that's what I would do... Steve
Hey, I thought this was gonna be EASY!??!
