Go Back   Home Recording > Equipment Forums > MIDI Mania
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-29-2004
bsr2002's Avatar
bsr2002 bsr2002 is offline
Denny Crane
bsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond reputebsr2002 has a reputation beyond repute
KORG X3 Workstation
I posted this in the keyboard forum by mistake
I just bought a YAMAHA Motif6, mainly got it for the sounds and I use it as my main gig board on the road.
I have a KORG X3 that I have been using as my primary workstation (yes outdated but works well) in my home studio.
I have been reading the YAMAHA Manual and I'm lost, so for now I would like to use the Motif as a tone generator going into my KORG. Since I am used to running this seq.
Getting it to make sound thru MIDI is not a problem... Since I've never used a tone generator in a sequencer before I need help in assigning the different sounds to the tracks on my sequencer. Especially the drums sounds, they sound really killer.
http://hire_on_the_fly.tripod.com
Unwanted e-mail = SPAM on the internet (not legal)
Infomercials = SPAM on the airwaves (Legal)
Junkmail = SPAM in your mailbox at home (Legal)
Check Out My Tunes
Old 04-30-2004
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Smile
I don't know much about Motif, does it have "Multi" mode or "Sequencer" mode?
I have N364 which works exactly like X3. Usualy, you only need to change bank and program number in sequencer mode, and it will also send the message to MIDI device connected. If it has different method of sending bank/program change command, then read MIDI implementation chart of Motif, and find out if you need to insert bank / program select message in Sequencer edit mode by using MIDI CC (Control Change) command (usualy 0 and 32).
Sequencer --> Edit --> Create Ctrl.
Sorry, I couldn't explain clearer right now. Be back latter
Jaymz
Keep Rockin' and Rollin'...
Old 05-01-2004
bsr2002's Avatar
Denny Crane
Thanks
Check Out My Tunes
Old 05-06-2004
bsr2002's Avatar
Denny Crane
Got it working but....
I'm having trouble setting the octaves. The Mo6 is playing lower notes
than the X3. I have tried pressing the octave buttons on the side and
when I play the keys manually it shows that the octaves have indeed
moved up. On playback however the notes stayed the same as before. I also
tried maxing up on the X3 but that didn't work either. Anything I'm
doing wrong?Thanks
Check Out My Tunes
Old 05-08-2004
James Argo's Avatar
Fancy Rock N' Roll
Hmmm, lets see if I can help you.
Korg X3
In Seq mode, press Edit. Go to lower page (1D). There you'll find transpose adjusment for each track of current song. Raise to +12 (an octave) or +24 (2 octave).
See...
Jaymz
Old 05-11-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
You should also be able to transpose an octave in your sequencer. When I used to sequence the Korg M1 I would run it in Combi mode and once I had everything setup for the song I would save it as a Combi Patch. That way I could just load up the patch and go and all the effects and everything were already set.
Old 05-12-2004
James Argo's Avatar
Fancy Rock N' Roll
Originally Posted by bsr2002
...so for now I would like to use the Motif as a tone generator going into my KORG. Since I am used to running this seq...
Which one is the master? Motif or X3? If X3 is the master (which means it plays sequencer, and send MIDI signal to Motif, then Motif makes sound), then you're gonna see my way will work better, because you don't play sequencer in Combi mode. Either way, when you use Motif as master then Tex said the way to go
Jaymz
