Old 04-27-2004
PoetSleep00's Avatar
PoetSleep00 PoetSleep00 is offline
Registered User
Location: beneath the rocks, where moss collects suspicious shades of blue and grey.
PoetSleep00 is an unknown quantity at this point
Exclamation Help!! TOO MUCH ANALOG
I've just purchased a Soundcraft 24:8 Spirit mixer. Before, I'd been recording with a Motu 828 & a G4. I understand the basic layout of the board, but this is my first true mixer. I don't know everything about mixing consoles, but since I've been into general recording, it has helped with my familarity with the basics multitrack recording. Basically what I'm saying is does anyone own this board? or someone who knows someone who does? I also, just received yesterday the KorgD1600 which I will be recording with. If anyone is experienced with this configuration of equipment, I'd appreciate the advice on connections & setup.
tHanks.
Old 04-27-2004
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
Just curious, why did you get an all-in-one unit like the Korg and an external mixer? I would have went with something like the HD24. You would of had 24 tracks to go with that 24 channel mixer.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 04-30-2004
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Did you get a manual? That would be the best place to start. You can check out the Mackie manuals at www.mackie.com They have some great setup diagrams. All mixers perform pretty much the same.
Old 05-01-2004
Registered User
I'm using the channels inputs of the mixer for my mpc 60 & sp1200. I assign each track to a bus and the busses are going into th korg d1600. I burn on a tascam cdrw700.
Thanks for the manual tip also. I need to see what other options I have. I'll gladly use the advice.
Old 05-01-2004
Adam P Adam P is offline
stuck in the money pit
Adam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond reputeAdam P has a reputation beyond repute
Like you said, run your 8 Bus sends into the 8 inputs on your recorder. Assign channels to different busses (guitar to bus 1, kick drum to bus 2, snare to bus 3, etc) and go from there.
Out of curiosity, why aren't you running the Soundcraft into the 828?
Old 05-03-2004
Registered User
I sold my 828. It was nice, but I was tired of all the things that could go wrong along the recording chain. 828 problems, OS problems, cord problems. I wanted to make process more basic. I didn't really like the 828 that much. It worked well for me, but there was too much stuff to turn on. The less switches the better. The closest I would ever get to one again is a digi 002.
