Old 04-24-2004
cellardweller's Avatar
cellardweller cellardweller is offline
Subterranean Sovereign
cellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond repute
Acoustic Treatment (trials and tribulations)
In a perfect world, people would come to this thread and post their "trials and tribulations" with room treatment.
My specific interest in this, those who have built the Ethan membrane bass trap, as opposed to those who have just used rigid fiberglass or mineral wool covered in cloth, or have done both and how drastic of a difference there is between them/with/without, different placement, gobo's, and "portable" traps, and yes even auralex etc, etc, etc.
Weather and finances haven't permitted me to get my traps built yet, so in the meantime.............
Old 04-25-2004
dobro dobro is offline
Moderator
dobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond reputedobro has a reputation beyond repute
I think you asked that question in a thread I started once. Here's what you asked and what Knightfly answered:
"What is the greatest advantage of membrane traps in corners over suspending rigid f/g in the corners. Is there a huge difference in low freq. absorption? Is effectiveness at louder volume levels a consideration between the two, or is it only a matter of absorption and wider bandwidth of frequencies?"
"The main advantage of membrane traps is lower frequency absorption in less space. They need to be placed flat against walls for best efficiency, where absorbent fiberglas traps are better diagonally across corners. Membrane traps absorb much less at higher frequencies, so help keep a room more "live" - so it helps to know the specific application before you can decide which will work better in what location... Steve"
Old 04-25-2004
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
I started off with just the fiberglas panels. The stuff does wonders I can say that. I figured it was easier and I saved some money but the good thing is, I already have the fiberglas. Alot of it is already cut into 2' x 4' panels that I can turn into wood panel traps later.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
Old 04-25-2004
You are correct, sir.
I didn't mean to make it so "pointed" to my singular issue. It seems somewhere (in one of these many acoustic forums) I heard that for smaller rooms that the figerglass "only" panels are as effective, but perhaps it was only meant that they are economically and ergonomically efficient. I probably read my own meaning into it, as I am prone to do...
I had to splurge to buy new PA cabinets the other day, because the ones I was borrowing from a friend were repossessed. I had intended on buying lumber, so this has set me back considerably.
Old 04-26-2004
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
"I had to splurge to buy new PA cabinets the other day, because the ones I was borrowing from a friend were repossessed" -
Bummer, man - we've all been there, so go ahead and whimper - too bad Lenon was so right when he said "life is the shit that happens to you while you're busy making plans", or something to that effect - hope your wallet loses its anorexic condition soon... Steve
Hey, I thought this was gonna be EASY!??!
Old 04-27-2004
Thanks,
*sniff, sniff*
I feel better already.
I actually found a good deal on some discontinued JBL's, but when you are 'po like me...
